Results 1 to 9 of 9
Thread: help, gps stopt working...
    May 2006
    Belgium
    hi,
    like the title says. my gps stopt working. at first it wouldn't connect to any satelite. now it says it's connected to 7 or 8 sats, but when i drive, it doesn't move...
    here's what i did to try to fix this:
    played a little with the settings in CF (switching from NMEA to SIRF)
    changed baud rates (9600, 38400, ...)
    changed com port
    removed gps and reinstalled it
    after changing settings i exitted CF and loaded it again
    what am i missing? it used to work fine, until (i think) i registered CF...
    will reinstalling CF help?
    Greetz
    Dj NRG
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    You need to isolate whther this problem exists in CF only. Try using a standalong GPS proggy liek GPSinfo form the USglobosat website and make sure that your receiver is sending through the information. If it is, then CF is most likely at fault. If your not receiving any info, then you need to look elswhere.
    You don;t have two programs using the same com port do you ?
    I installed my carpc into my pet Kangaroo, mate.
    May 2006
    Belgium
    thx for the reply.
    i formatted my windows yesterday, because some com ports were acting crazy. guess the problem is solved now. i'll test it today..
    Greetz
    Dj NRG
    May 2006
    Belgium
    works perfect...
    Greetz
    Dj NRG
    Nov 2007
    hello, could you tell me what the problem was and how you fixed it? i have the exact same problem...
    May 2006
    Belgium
    read 2 posts above: i formatted my pc and problem was solved, so not sure what caused this problem...
    Greetz
    Dj NRG
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Dj-[NRG] View Post
    Greetz
    Dj NRG
    Thought you still had a problem destinator acting crazy :s
    Nov 2007
    i`ve concluded that my gps receiver is not working.. downloaded gpsgate and it cannot get any signals from the receiver.. i`ve bought a new one..
    http://www.holux.com/JCore/en/produc...nt.jsp?pno=227
    holux M1200.. hope that will do the trick..
    May 2006
    Belgium
    Quote Originally Posted by Laidback View Post
    yes i do, but that's a different problem and a different thread...
    Greetz
    Dj NRG
  1. Replies: 91
    Last Post: 11-07-2006, 05:47 PM
  2. NMEA GPS not fully working
    By stric in forum FreeDrive
    Last Post: 03-07-2006, 05:25 PM
  3. MapMonkey Gps working but not on map
    By BOND007BE in forum Map Monkey
    Last Post: 03-11-2005, 10:02 AM
  4. Deluo Gps not working
    By juixy in forum GPS
    Last Post: 07-26-2004, 06:16 PM
  5. Got GPS 16 working
    By tekknikal in forum General Hardware Discussion
    Last Post: 06-16-2002, 07:55 PM
