+ Reply to Thread
Results 11 to 20 of 28
Thread: Centrafuse Beta 1.40
  1. #11
    Mar 2005
    Pomona, CA
    Quote Originally Posted by veetid View Post
    There is an issue with large lists that we are working to get fixed, it does not properly slow down...
    I was just about to post about this... good to know its already being looked into.
  2. #12
    Mar 2005
    Pomona, CA
    I just had a problem this morning.
    Last night I installed 1.4 and was playing with XM. All was working fine. I came back this morning and noticed CF "loading" the day skin. It never finished loading, and froze on the loading screen with the XM app open.
    I had to restart the computer, and after reloading CF, the XM plugin was missing!
    Any idea what happened there??
  3. #13
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Quote Originally Posted by sivart321 View Post
    Is there still a directory "<CFInstallDir>/Plugins/SatRadio" ? And XM is missing from Settings as well? I probably can be of little help on this one, David will chime in of course...
  4. #14
    Mar 2005
    Pomona, CA
    Quote Originally Posted by smeesseman View Post
    It is no longer in settings. There is a blank item that does nothing when clicked. I also do not believe there was a directory either. Ill go check.
  5. #15
    Jul 2005
    Hi
    I'm unable to save the FM radio stations channels, I press the button for a channel and hold it down, the button hilites, after a few seconds the hilite disappears. But the channel is not saved!
  6. #16
    Constant Bitrate Lazyflip's Avatar
    Mar 2005
    FL
    Quote Originally Posted by clarkie View Post
    Hi
    Are you using the Silabs USB? If so this is an already known issue. Check this thread: http://forums.fluxmedia.net/showthread.php?t=1660.
  7. #17
    VENDOR - Centrafuse veetid's Avatar
    is it still in the plugins folder? Can you post your error.log?
    david
  8. #18
    Mar 2005
    Pomona, CA
    david
    The satradio folder is still there...
    10/14/2007 8:35:10 PM
    Could not find a part of the path "C:\Documents and Settings\Travis\Application Data\CFBluetoothControl\Temp\".
    at System.IO.__Error.WinIOError(Int32 errorCode, String str)
    at System.IO.Directory.InternalGetFileDirectoryNames( String fullPath, String userPath, Boolean file)
    at System.IO.Directory.InternalGetFiles(String path, String userPath, String searchPattern)
    at System.IO.Directory.GetFiles(String path, String searchPattern)
    at CFBluetoothControl.BluetoothControl.UninitBluetoot h()
    10/14/2007 8:35:28 PM
    Cannot access a disposed object named "main".
    Object name: "main".
    at System.Windows.Forms.Control.CreateHandle()
    at System.Windows.Forms.Form.CreateHandle()
    at System.Windows.Forms.Control.get_Handle()
    at System.Windows.Forms.Control.CreateGraphicsInternal()
    at System.Windows.Forms.Control.CreateGraphics()
    at centrafuse.main.updateMainTitle(String text, Boolean scroller)
    Object reference not set to an instance of an object.
    at centrafuse.Music.updateTitle(Boolean resetposition)
    10/14/2007 8:47:01 PM
    Index was out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index
    at System.Collections.ArrayList.get_Item(Int32 index)
    at SatRadio.satradio.tuneChannel(Int32 channel)
    10/15/2007 8:42:10 AM
    The root element is missing.
    at System.Xml.XmlTextReader.Read()
    at System.Xml.XmlValidatingReader.ReadWithCollectText Token()
    at System.Xml.XmlValidatingReader.Read()
    at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
    at System.Xml.XmlDocument.Load(XmlReader reader)
    at System.Xml.XmlDocument.Load(String filename)
    at centrafuse.Plugins.ConfigReader..ctor(String configpath)
    at SatRadio.satradio.loadSettings()
    at SatRadio.satradio.CF_pluginInit()
    10/15/2007 8:42:34 AM
    at SatRadio.satradio.CF_pluginUpdateLanguageSkin(Stri ng language, String skin)
    10/15/2007 8:49:24 AM
    Could not find a part of the path "C:\Documents and Settings\Travis\Local Settings\Application Data\PluginsInactive\".
    at System.IO.Directory.InternalGetDirectories(String path, String userPath, String searchPattern)
    at System.IO.Directory.GetDirectories(String path, String searchPattern)
    at centrafuse.filebrowser.loadList(String path)
    10/15/2007 6:02:49 PM
    Specified cast is not valid.
    at CFBluetoothControl.BluetoothControl.itemList_Selec tedIndexChanged(Object sender, EventArgs e)
    at centrafuse.Plugins.skinListbox.SetSelectedIndex(In t32 pi_iNewIndex)
    10/15/2007 6:13:02 PM
    Could not find a part of the path.
    at System.IO.DirectoryInfo.MoveTo(String destDirName)
    at centrafuse.main.CheckPluginQueue()
    10/15/2007 6:13:13 PM
    10/15/2007 6:17:39 PM
    10/15/2007 6:17:41 PM
    Could not find a part of the path "C:\Program Files\Flux Media\Centrafuse\REMOVEDPLUGINS".
    at centrafuse.okbox.CopyDirectory(String sourceDirectoryName, String targetDirectoryName)
    10/16/2007 12:07:47 PM
    The underlying connection was closed: The remote name could not be resolved.
    at System.Net.HttpWebRequest.CheckFinalStatus()
    at System.Net.HttpWebRequest.EndGetResponse(IAsyncRes ult asyncResult)
    at System.Net.HttpWebRequest.GetResponse()
    at System.Xml.XmlDownloadManager.GetNonFileStream(Uri uri, ICredentials credentials)
    at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials)
    at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
    at System.Xml.XmlTextReader.CreateScanner()
    at System.Xml.XmlTextReader.Init()
    at weather.setup.searchResults()
    10/16/2007 12:09:58 PM
    10/16/2007 12:10:06 PM
    10/16/2007 12:12:05 PM
    Thread was being aborted.
    at System.Windows.Forms.SafeNativeMethods.UpdateWindow(HandleRef hWnd)
    at System.Windows.Forms.Control.Update()
    at System.Windows.Forms.Control.Refresh()
    at centrafuse.okbox.recursiveAdd(String rpath)
    10/16/2007 12:12:13 PM
    10/16/2007 12:13:26 PM
    10/16/2007 12:13:48 PM
    10/16/2007 12:13:49 PM
    Could not find file "C:\Program Files\Flux Media\Centrafuse\plugins\SatRadio\languages\.xml".
    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
    at centrafuse.Plugins.LanguageReader..ctor(String langpath)
    at SatRadio.setup..ctor()
    at SatRadio.satradio.CF_pluginShowSetup()
    10/16/2007 12:13:53 PM
    10/16/2007 12:15:12 PM
    10/16/2007 12:15:30 PM
    10/16/2007 12:17:00 PM
    10/16/2007 12:17:01 PM
    10/16/2007 12:17:40 PM
    10/17/2007 6:01:18 PM
    10/17/2007 6:01:33 PM
  9. #19
    Jun 2006
    hello david, i'm unable to download the 1.40 version.
    Thanks for this amazing product!
    VIA EN15000 C7 // CTF700 7" Screen // Morex 3688 Black Case
    M2-ATX // 80GB HD
    DVD-RW // PowerMate
    Belkin Bluetooth V1.2 // Hauppauge WinTV FM
    Centrafuse RC5
    JBL GTO 75.4 520W // Pionneer Kevlar 260w Speakers
  10. #20
    I will have 1.42 up in a matter of days...
    found an issue with 1.40 and wanted to stop users from updating until 1.42 comes out...
    working on it now...
    david
+ Reply to Thread
  1. Centrafuse 1.30 Beta Update and Infill Support
    By veetid in forum Centrafuse
    Last Post: 09-30-2007, 05:57 PM
  2. When can beta Centrafuse no longer be used?
    By dsj1979 in forum Centrafuse
    Last Post: 01-01-2007, 09:34 PM
  3. Centrafuse Beta - embedded GPS?!
    By Psychobiker in forum CF FAQs
    Last Post: 02-14-2006, 07:35 AM
  4. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  5. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
