The latest XM plugin is also included, it is fully functional. We have to get the buffer code added and working, but this will be in a SatRadio plugin update soon...
david
Centrafuse Beta 1.40 is ready to download. This includes most of the fixes and updates that will be ready for the official 1.50 release.
Download the installer and make sure when it starts the path to extract is set to your Centrafuse installation location, it defaults to "C:\Program Files\Flux Media\Centrafuse"
http://www.fluxmedia.net/downloads/CF140.exe
You can see a list of everything added and fixed since the official 1.20 release here:
http://forums.fluxmedia.net/showthread.php?t=1661
The remaining issues in 1.40 are below:
http://forums.fluxmedia.net/showthread.php?t=1660
All you need is Centrafuse 1.20+ installed. This includes a new Skin, Aura... You will simply need to change the Skin in General Settings after installing the update. It includes the plugins Weather, OBDII, and Email... The CFEmail needs to be installed before you install this update if you use it...
There are updates and fixes for Weather, OBDII, and Email included...
There is a System\throwscrolling.xml file you can use to edit settings for the finger scrolling on list views. There is an issue with large lists that we are working to get fixed, it does not properly slow down...
There are very basic gestures included, up/down/left/right... This can be enabled from System\gestures.xml, there is a True/False flag at the top as well as settings to determine what actions are performed... We are still working out some issues with the gestures so just very basic support is in this release...
david
david
any screenshots of the new skin?
Here is a quick update for a mixer display issue, this is a single centrafuse.exe that must be copied to your "Program Files\Flux Media\Centrafuse" folder, AFTER INSTALLING the full Centrafuse 1.40 Beta...
http://www.fluxmedia.net/downloads/CF141.zip
david
will this new skin remain thru 1.5? I'm getting anxious to skin cf again & if this newest seems to have some longevity then I'll start there, or do you think I should wait for 1.5?
The skin has not changed in quite awhile, the new skin in 1.4 follows the same model as the 1.2 skin...
no reason not to start skinning...
david
cool, thanks![]()
here is a screenshot
purty :-D
