Results 1 to 5 of 5
Thread: Speed Camera
    Dec 2006
    Speed Camera
    Hi,
    Is there any way to add the csv file of cameras from the map monkey website into the centrafuse destinator map, to show and warn for all cameras?
    IAn
    Jun 2004
    Yamba NSW Australia
    Constant Bitrate ivanmx6's Avatar
    Dec 2006
    Dorset, UK
    There's actually a way of adding speed camera warnings using just Centrafuse.
    Import the camera files as Favourites. Once there you can have them displayed on the map.
    This needs a bit of work in Destinator - basically you need to edit the favourites to show them on screen and to set the warning distances.
    Then just place a .wav file named exactly the same as your favourite in the folder \Voice\All
    (eg, if you have a favourite called Gatso, you need a Gatso.wav)
    Some useful wav files are here: http://homepage.ntlworld.com/ken.hol...C/WAVfiles.zip
    These are the ones I use - you will need to rename them depending on your favourites.
    Constant Bitrate pijo1971's Avatar
    Nov 2004
    Novara - Italy
    hi,
    could you explain how is the format of the file that can be loaded? is it a .csv file? what is the record tracing?
    and exactly, what do you mean with
    and with
    thanks in advance,
    pijo
    CarPC in Progress [||||||||-] 90%
    Visit my Project
    Variable Bitrate marazi's Avatar
    Dec 2005
    Skien, Norway
  1. Speed Camera input screen help required
    By tolisn in forum FreeDrive
    Last Post: 07-07-2005, 01:42 PM
  2. Speed camera detection software on laptop
    By rickyaswell in forum LCD/Display
    Last Post: 08-26-2004, 07:13 AM
