I installed this ontop of 1.30 and now nav doesnt work at all.
If i press the nav button this happens:
And if I try to edit and save the changes of navigation i get a .NET error and CF closes.
I just tested and it is saving for me... can you open the file:
"C:\Documents and Settings\David\Local Settings\Application Data\Centrafuse\Presets\Custom.xml", you will see the bands in the XML, the last one is 15k and it should be getting updated as you move the slider...
david
so it is not an issue with just the 15k, but they all do not update sometimes? can you post your error.log?
david
