Centrafuse 1.42 Beta is ready to download. The official update will be Centrafuse 1.50, which we hope to have ready this month.
This will update and install on top of Centrafuse 1.20+
Download 1.42 and install on top of your current Centrafuse installation.
http://www.fluxmedia.net/downloads/CF142.exe
Make sure you set the installation path to the location you installed Centrafuse, it will default to your "<Program Files>\Flux Media\Centrafuse" folder.
Anyone who was running 1.40 or 1.41 should upgrade to 1.42, there were some major issues fixed in 1.42.
1.42 has some major updates, the audio engine has been updated. The tag reading code has been improved as well, especially with APE tags.
The DVD now works in Vista. It also has new features under the DVD menu. You can change the audio streams, change subtitles, toggle the display mode from native to stretch mode, as well as play DVD folders from your hard drive.
The visualization code was complelty rewritten, they should move to the beat a lot better as well as move much faster. We included 3 new visuals in this update. You can download more visuals below.
Visualizations:
http://support.xmplay.com/file.php?cat_id=6
The latest SatRadio code is included. XM and Sirius are both fully supported in both buffered and non-buffered mode.
Check the release notes for all the fixes in 1.42.
Release Notes:
http://forums.fluxmedia.net/showthread.php?t=1661
Below is a list of the remaining issues that have been reported.
Remaining Issues:
http://forums.fluxmedia.net/showthread.php?t=1660
Some of your plugin settings might get reset when installing this update including Email, OBDII, SatRadio, and Weather.
david
