I am looking into speeding up the building controls speed, should not be a problem...
need a little more help finding the media library slow down issue... Does it create an error.log? This should not be hard to fix once I find it...
Is it only in album art view?
david
No error.log for me in Centrafuse root folder.
I have tested with "cover art" disabled.
The slow down issue happens when I navigate through "Music folder" in library only when I try to enter in an album folder (with severals MP3 inside it).
It does not happend when navigating through empty sub folders, only when you try to go in sub folder which contain many files (more than 15).
It looks like Centrafuse is trying to load IDTAGs of the MP3s each time you enter the folder.
I have found the issue.
Disable "FOLDER TAG READING" in "Settings/AUDIO-VIDEO".
did you have folder tag reading enabled before? I did change some of the tag reading code, which is called every time you enter music folders... when disabled it just shows the file names which would be faster...
I added support for more tag formats, this could have added a small delay per file it loads to read the tags, which could compound when scanning multiple files...
when not using music folders it reads from the database which should not have changed in performance...
everyone having the issue with slower performance in media library are you using music folders? this would narrow down the issue to the new tag reading code...
david
We have double thread on this subject.
Let's continue HERE.
Any word on a new release to fix these issues? This current release isnt usable for me.![]()
it's coming... all bugs fixed, just finishing up the new navigation screens... the navigation skin has been improved a lot...
should finish tonight hopefully, test tomorrow, and hopefully post before the weekend...
david
Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
I finished the installer a couple of hours ago... Doing some internal testing to make sure there are no obvious bugs or issues with the updater, also waiting on some translations...
plan to release it tomorrow, and also we will be releasing the new WiFi manager to control all your WiFi connections from Centrafuse...
david
