Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Media Library Slow...
  1. #11
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    It seems like the problem comes from the "FOLDER TAG READING"
    Disable "FOLDER TAG READING" in "Settings/AUDIO-VIDEO" and try again and post again. here or there.
  2. #12
    Jun 2007
    Thanks for the tip, i'll check it and send you feedbacks
  3. #13
    Aug 2005
    Quote Originally Posted by coucouillu View Post
    What exactly does that do anyways? I always wondered.
  4. #14
    VENDOR - Centrafuse veetid's Avatar
    this determines whether it reads the tags when browsing by folder or if it just shows the file names...
    So everyone with slower media browsing, are you using the music folders option or artist/album sections?
    I did update the tag reading code and add supported for more formats, fixed a bunch of APE tag reading issues, and improved some of the ID3 reading code...
    when browsing not by music folders it is reading from the database, this should not have changed in performance... when browsing music folders with tag reading turned on it reads the tags as you browse, when disabled it just shows the filenames and this would be faster...
    help me determine what issue everyone is having and I will get it fixed up...
    david
  5. #15
    Aug 2005
    Ok I guess ill start.
    I have Folder Tag Reading on (Depite not knowing what it did untill now)
    I Don't use Folder Browsing but i did test it and I thought the speed was fine.
    My Slow downs are using coverart. Which is the way i typically browse.
  6. #16
    Nov 2004
    FRANCE
    Quote Originally Posted by veetid View Post
    You are right. No change.
    It is exactly what I feel.
    I am quite sure that the problem comes from the Folder Tag Reading option
    music folders --> slower
    artist/album --> faster
    did you have folder tag reading enabled before?
    I have this option enable since 1.2 and had never change it.
    The slow bug appears since 1.4X update (I can't remember if it is 1.42, 1.43 or 1.44)
  7. #17
    Nov 2004
    FRANCE
    Quote Originally Posted by SKiTLz View Post
    Please try Folder Tag Reading "on" use Folder Browsing through folder which contain more than 20 mp3's (more if you could) with full TAG (artist, album, year, etc).
    It should slow down.
  8. #18
    Aug 2005
    Yes it does. I have my archive structured as so.
    A
    ---Artist
    ---------Album
    B
    C
    Because of that i didn't have any folders with mass amounts of songs on one directory. I through a bunch in one dir to test and it was quite a bit slower.
  9. #19
    Newbie SBDJ's Avatar
    Nov 2004
    At The Bar!
    I use the "Music Folders" option.
    Folder Tag Reading set to off has sped up the folder browsing no end, much much much better.
    Skipping between tracks is still slow for me however. I'll do some more testing with this though
    SB
    "The gene pool could use a little chlorine..."
  10. #20
    I will look into this... In all the 1.4x releases I had updated code for the tag reading... there was actually a few bugs that made it not completly scan files for certain tags, which is why it was probably faster due to the bug itself...
    I will try to speed up the tag reading, but for now just turn off folder tag reading and it should be as fast as it can be...
    david
  1. muting after going into media library
    By danwheeler in forum Centrafuse
    Last Post: 02-23-2007, 11:17 AM
  2. skinning winamp media library
    By sideone in forum Road Runner
    Last Post: 11-25-2006, 03:11 PM
  3. media library
    By thecapitalizt in forum MacCar
    Last Post: 08-01-2005, 02:03 PM
  4. Media player that works with iTunes?
    By serendipity in forum Software & Software Development
    Last Post: 01-18-2005, 07:47 AM
  5. Adding file syncronisation to Media Engine
    By skippy76 in forum Media Engine
    Last Post: 03-26-2004, 11:01 PM
