Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 60
Thread: Centrafuse 1.45 Update
  1. #11
    Aug 2005
    Quote Originally Posted by SKiTLz View Post
    P.S What is it doing when it says "Building Controls".. Cause that part of the load seems to get slower and slower with every release.
  2. #12
    VENDOR - Centrafuse veetid's Avatar
    that section did get a little slower, it loads the visualization during that call... you can remove visuals you don't use and it will get a little faster...
    the other is each one of these updates has been including additional plugins, which increases load time... remove any folders from Plugins for ones you do not use and it will also increase load time...
    david
  3. #13
    Aug 2005
    Quote Originally Posted by veetid View Post
    david
    Ok thanks. I don't use quite a few so I'll clean up a little..
    probably not something i will notice in the car.. I just notice it more now cause im constantly stopping/starting centrafuse setting things up.
  4. #14
    Aug 2005
    error log is located:
    "C:\Documents and Settings\<username>\Local Settings\Application Data\Centrafuse\error.log"
    some have reported issue with WiFi not registering properly...
    you can remove the WiFi plugin from the Plugins folder and it should start properly...
    if you had issues with installer at the end, it was probably registering the WiFi DLL, run the following...
    click start, run, type cmd...
    at the prompt type...
    regsvr32.exe C:\Windows\System32\WiFiMan.dll
    then try with the WiFi plugin again...
    david
    FYI. Reregistering the DLL didn't help. Still can't get it to start with the WifiManager.
  5. #15
  6. #16
    Newbie SBDJ's Avatar
    Nov 2004
    At The Bar!
    I also have the same issue
    SB
    "The gene pool could use a little chlorine..."
  7. #17
    there is an issue with the WiFi on some systems, it has been fixed... I will post a quick 1.46 update later today or tomorrow...
    david
  8. #18
    Quote Originally Posted by coucouillu View Post
    cancel route button under Navigation doesn't work.
    The trip planner is still here after route cancelled.
    it calls the same code as it use too, did cancel route use to work?
    what do you mean the trip pllaner is still there?
    david
  9. #19
    Nov 2004
    At The Bar!
    Cool, thanks... not had any other issues as yet, and liking the new navigation layout too
    SB
  10. #20
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    David,
    Surely you must get sick of us all coming in here and tearing down your hard work...
    Although the error I previously mentioned came up, everything still works fine except the WIFI manager doesn't work, but that's been sorted.
    I noticed that with the new gps skin (looks great btw) the shortcuts to Fuel, Food and Acomodation don't actually take you directly to that section of the POI's. Pressing each one just takes you to the main list of POI's available and not to the specific section relative to the button that was pressed
    I installed my carpc into my pet Kangaroo, mate.
  1. Centrafuse 1.14 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-01-2007, 11:34 AM
  2. Centrafuse 1.2 Updater
    By M15t4B in forum Centrafuse
    Last Post: 06-19-2007, 08:37 PM
  3. Centrafuse 1.2 Installer Update
    By veetid in forum Centrafuse
    Last Post: 06-15-2007, 11:56 PM
  4. New Release, Centrafuse 1.14
    Last Post: 06-05-2007, 12:36 PM
  5. XM update song
    By rjoek in forum Road Runner
    Last Post: 08-06-2005, 02:01 AM
