Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 60
Thread: Centrafuse 1.45 Update
  1. #41
    Low Bitrate wmpwi's Avatar
    Sep 2007
    Western Michigan
    Quote Originally Posted by veetid View Post
    I just found some code that was increasing the start time a lot... The email plugin was causing a lot of it, but it was others as well...
    the startup time will be decreased in the next update 1.46 which I plan to release later today with the WiFi fix as well, and others posted...
    david
    I may not have the history on carputers as most do in the forum, but I've been knocking around desktops and software since the mid 70's and you don't see this kind of customer support too often or this quickly. It's clear the people at Flux are dedicated to their product and customer base and take pride in their work. If anyone thinks I'm off the mark, feel free to check out a few other update threads.
    Nice job guys.
    A computer helps you make more mistakes faster than any invention in human history
    - with the possible exceptions of handguns and tequila.
  2. #42
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    Hi,
    In Navigation, is it possible to remember the last city used? Everytime I enter an address I have to type the city (using city / street).
    I am using the Brazil maps and when I click the new Gas, Food or Lodging buttons they are showing the entire POI category list (the same issue somebody else described earlier). I know that this map is not supported by you, I bought it for my PocketPC and I am using the files (the only option I have). When the button is pressed, are you loading a POI category code (number) or a POI category name? Maybe if you make it read the code or name from a .ini file, anyone can choose what POI categories they like to open in that buttons.
    Btw, this frontend is fantastic, very easy to use and powerful. Good job.
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
  3. #43
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Quote Originally Posted by sivart321 View Post
    I dont know if I mentioned it before (along with the radio plugin being muted entirely) or if it was known, but almost everytime I resume from hibernation the buffered music is playing in the background with the media that is currently playing. When you leave media and enter XM, it would correct and play only media. However, if you left XM and messed around with any other functions in CF and then clicked back into XM, it would pause. No audio at all.
    I want to make sure I have things straight so I can look into this - In this situation, when gone into hibernation, Media was the audio source? And out of hibernation XM started playing when it shouldn't have been, then you went into XM and the XM in the background stopped playing? And the Media kept playing? Then clicking back into XM caused all audio sources to not work?
  4. #44
    Mar 2005
    Pomona, CA
    Quote Originally Posted by smeesseman View Post
    A couple cases...
    1. Playing Media
    2. computer hibernates
    3. resume from hibernate (in media) and XM plays through. (both media and XM are playing)
    second case.
    1. Playing XM
    2. click back, go to weather, windows (minimize), etc
    3. go back to XM to change station and xm pauses or mutes itself (no audio playing at all now)
    The problem with radio was totally unrelated it seems...
    When I click on radio, there is no audio at all. All of the functions work (RDS, seek skip, etc) but there is no sound.
    If I go into the windows mixer and unmute the radio line-in and mute it again, the radio will then play. However, if I leave or change stations the audio stops playing.
    The stuttering I mentioned above is by far the more annoying issue... the rest of the things (minus the radio not working) have work arounds I can deal with. The stuttering just drives me crazy.
    Thanks for the help.
  5. #45
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by vladcarpc View Post
    Hi,
    1.45 should remember the last postal code and city that was used and auto highlight when you go back to that list...
    post the details in your WCE.txt file...
    david
  6. #46
    Nov 2006
    Sao Paulo, Brazil
    Great, I'll test it later today.
    david
    OK, here is the content of WCE.txt file for the Brazil Q2 2007 map:
    Code:
    Brazil:
    Brazil
    Version 2007.Q2.0 - Map of DigiBase. Main graph V1.4, HLG3, WES2, D01. Signed map
    Original file attached.
    Thank you!
    Attached Files Attached Files
    \/ |_ /\ [)
    1995 Civic Sedan EX
  7. #47
    The maps for Brazil I added support for and that we support are GDT, they will be sold on the website soon...
    I can look to make this read from a config file but of course Destinator did not make it easy, I do it based on a number category ID, which you have no way of getting... Doing it based on text for all the different countries would have been a nightmare, but it ended up being a nightmare anyway...
    david
  8. #48
    1.46 will include a file called poicategories.xml, this will let you override what the category ID's are for each map in your folder...
    Also included is a DestinatorPOI.exe file which will load up and give you the category ID for each POI in the list... You will figure out what the ID is for your map, then enter it into the poicategories.xml file and it should load up and work for all maps that are setup...
    david
  9. #49
    May 2006
    Seattleish, WA
    Hey David... in the 1.43 update you mentioned:
    This will also reset your button actions.
    In the final 1.50 final release it will be an upgrade and not change any of
    your settings, this is just in the Beta updates.
    This will also change your default skin to the new Aura skin, you can
    easily change this back in Settings if you are using the older skins.
    Is this still an issue with 1.45 or the upcoming 1.46?
    :: Mark
  10. #50
    Nov 2006
    Sao Paulo, Brazil
    david
    Excellent!!! That was fast! Thanks
    \/ |_ /\ [)
    1995 Civic Sedan EX
  1. Centrafuse 1.14 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-01-2007, 11:34 AM
  2. Centrafuse 1.2 Updater
    By M15t4B in forum Centrafuse
    Last Post: 06-19-2007, 08:37 PM
  3. Centrafuse 1.2 Installer Update
    By veetid in forum Centrafuse
    Last Post: 06-15-2007, 11:56 PM
  4. New Release, Centrafuse 1.14
    Last Post: 06-05-2007, 12:36 PM
  5. XM update song
    By rjoek in forum Road Runner
    Last Post: 08-06-2005, 02:01 AM
