First of all, I'm not good at English. ^^;
I'm using Centrafuse with dual monitors.
In 'SETTINGS', I set 'VIDEO DISPLAY' to 'DISPLAY2'.
When I load & play multiple video files, and click 'album art / visualization area' to view full-screen video in secondary monitor, video window in primary monitor is not off.
It loads two ffdshow filters, and when I change video files, more and more ffdshow filters are loaded.
Can I disable video window in primary monitor when I activate full-screen video in secondary monitor?
PS.
'ffdshow video decoder configuration > DirectShow control > Multiple ffdshow instances:' are not working too.
Yes, It causes hundreds of fliters to load and they remain in memory.
1. play video -> one ffdshow (or other) filter is loaded.
2. change to full screen -> one more filter is loaded. Now number of loaded filters are two.
3. change to another video files -> only one of two loaded filters is unloaded. And two more filters are loaded. Now number of loaded filters are three.
4. change to another video files -> only one of three loaded filters is unloaded. And two more filters are loaded. Now number of loaded filters are four.
5. and so on...
about 4MB per one ffdshow filter...
(FFDShow MPEG-4 Video Decoder 2007-12-15 from http://www.free-codecs.com/download/FFDShow.htm)
Thanks, david.
where are you seeing this memory increase? I just tested and it appears to be working for me...
do you see the new filters loading on the centrafuse.exe process? what are you using to view them? does it happen with one video loaded or just when you have 2?
david
I see the issue now... The secondary small video is disposed, but it is not cleaning up properly... I will try to fix it, and if not remove the video on the primary screen when using a secondary display for memory...
david
this has been fixed...
david
Thanks, david.
