Page 3 of 16 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 157
Thread: New Phone Software
  1. #21
    Variable Bitrate Jistari's Avatar
    Dec 2007
    New York
    Well, at least Ill know not to waste time trying to get that combo to work. Thank you Nola
    PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
  2. #22
    Feb 2008
    Thanks 4 that info..
  3. #23
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Just wanted to throw an update out there that the new Bluetooth Module is working very well so far in alpha testing. Say goodbye to your bluetooth phone woes if you had them . It will be ready very soon for beta testing...
    To answer the question I already saw a few times, and will be asked again, if you're phone supports the handsfree profile, it should work with our solution. If it supports the headset profile only it will still work but with limited functionality. And yep, to the more specific question we'll get, blackberry and iphone both support handsfree profile.
    List of Current Basic Features:
    Search for devices
    Save and pair to multiple devices
    Connect/AutoConnect
    CallerID
    CallWaiting
    Signal Status
    Battery Status
    Multiple-Caller Support
    Basic Phonebook
    VCard Importer
    OBEX Server to accept contact push from remote device, integrated with phonebook
  4. #24
    Mar 2007
    Detroit, MI
    Quote Originally Posted by Jistari View Post
    Ordered CF XE, never got phone to work, BlueSol see's phone (Motorola i580), and links with it, shows up in CF, but wont dial or answer.
    Oh well, waiting for the new phone patch.
    CF 1.47 and below does not use Bluesoleil, the version you are using supports the Broadcomm stack. Do you mean Broadcomm? No matter, Centrafuse with the new phone build will be available very soon, and no longer uses the unreliable broadcomm stack.
  5. #25
    Dec 2007
    New York
    Thanks Smees.
    Bleusol was what was on there when I got the system (with CF installed) from the vendor.
    No matter, I have uninstalled it and will wait for the new patch.
  6. #26
    Newbie blckwdw's Avatar
    Apr 2006
    Lansing, Michigan
    Hardware?
    will any USB Bluetooth adapter work for this or will there be a specific adapter required. Mine is a USB 2.0 Bluetooth 2.0 adapter. In windows it says "Generic Bluetooth Radio"
    "Toilets scare the crap of of me..."
  7. #27
    Jan 2008
    I have a bluetooth chip that uses the toshiba driver for bluetooth stack it supports pretty much all the bluetooth profiles.....Are widcomm drivers going to be required for the new phone interface? hopefully not.
  8. #28
    Mar 2007
    Detroit, MI
    The new phone utility will include all software necessary to locate and use your usb bluetooth device. No extra drivers will need to be searched for, and although we do not have a list of specific bluetooth dongles that are supported, there are a WIDE range of them that are. The only dongle that I believe will not work are Broadcomm based, which require firmware upload on init from what I remember. If anyone is looking for a recommendation, I am using DLink DBT-120 for most of the testing, and it has been flawless.
  9. #29
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Scott, MOST BT dongles I've ever used are Broadcomm-based. What drivers does the D-Link dongle come with?
  10. #30
    Jan 2007
    New Orleans, LA
    Nevermind, I see it uses the Toshiba stack. Interesting. If CF won't support any Broadcom-based dongles, that is going to significantly limit the amount of usable dongles since the majority of dongles are Broadcom. But it could be worse... you could be required to buy a proprietary dongle for a BT module that doesn't even work... like some other F/E's.
  1. BlueTooth Mobile ( Cell ) Phone Software
    By AMC 96 TE Magna in forum Wireless Communications
    Last Post: 03-23-2006, 07:44 AM
