Page 7 of 16 FirstFirst 12345678910111213141516 LastLast
Results 61 to 70 of 157
Thread: New Phone Software
  1. #61
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Yeah I would also hope they are going to provide a list of compatible dongles as well.
  2. #62
    Newbie mJrO's Avatar
    Jun 2005
    Portugal
    my bt is CSR - Cambridge silicone radio. You should be able to see it on the properties (either in the bluetooth software or the hardware list)
    2005 S40 2.0D - Sport Body Kit
    Ipod 100%
    Carpc 95%
  3. #63
    Jan 2007
    New Orleans, LA
    Quote Originally Posted by mJrO View Post
    But for those of us that don't already own a dongle, or currently own a Broadcom one, we need to know which one to buy.
  4. #64
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Ok,
    How do you tell if a dongle is CSR or ISSC based -- I looked on my system properties and didn't find anything about what chipset my Kensignton USB bluetooth adapter (2.0) is using.
    Nasa
  5. #65
    Aug 2007
    Lake Charles, Louisiana
    What's the best solution for a BT dongle to use with this new stuff? Any suggestions as I tried searching, but mainly want it to work with CF the best.
    2000 Pontiac Trans Am Firehawk #102
    Processor: AMD 64 X2 BE-2350 (Dual Core)
    Motherboard: ABit NF-M2S (Micro-ATX)
    Memory: 2GIG Crucial DDR2 667
    Hard Drive: WD 160GIG
    Monitor: 7" Lilliput 629GL
    Front End: CentraFuse With Navigation
  6. #66
    Jan 2007
    New Orleans, LA
    Infinite, read the thread (at least pgs. 3 - 5) and you'll see what's been discussed about this so far.
    By the way, I have that exact CPU you have for my new PC, and that thing is awesome!
  7. #67
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Quote Originally Posted by nasa View Post
    Ok,
    Nasa
    If you have a Windows Bluetooth software installed, i.e. a "My Bluetooth Places", etc, it usually says somewhere in the local device properties pages. Also, a tool like USBView will usually give you a hint about the chipset in plain text. It definitely will give you a vendor id, which for CSR would be 0x0A12.
  8. #68
    Mar 2007
    Detroit, MI
    Addressing the question about supported USB dongles:
    It does seem as if many broadcomm devices will be supported looking through the USB inf's that we have. When we find out for sure what is supported by our stack vendor, we will be sure to get that information out to everyone.
  9. #69
    Mar 2007
    Detroit, MI
    Quote Originally Posted by Habious View Post
    Can the dumber of us assume that you're going to provide a definitive list of adapters that do work?
    A Bluetooth dongle running a Wincomm stack version 1.7 versus the hardware ISSC-based Bluetooth dongle-free adapter....huh?
    Just tell me which one to buy. "Bob's Bluetooth dongle, Model 1A"...I'll get that one and be done with it!
    We have been using a Dlink DBT-120 in testing, it's been flawless.
  10. #70
    Sep 2003
    Vic. Australia
    I did a bit of digging around, according to smeesseman bluetooth dongles containing CSR or ISSC chips should be fully compatible. Below are the vendor IDs for these two:
    ISSC Vendor ID: 0x1131
    CSR Vendor ID: 0x0a12
    Additional the broadcom vendor ID is 0x0a5c which is NOT compatible.
    So... how do you find out the vendor ID of your bluetooth adaptor... go to Device Manager, double click on your bluetooth dongle (there will be several devices relating to bluetooth, on my system the correct one was "Bluetooth USB controller"), go to the details tab, once in the details tab select hardware ids from the property dropdown menu, you should see something like VID_0000 where 0000 is the vendor ID.
    Hope this helps guys. By the way, vendor ID list was taken from http://fxr.watson.org/fxr/source/dev/usb/usbdevs (there are plenty of other vendors listed if anyone wants to check theirs.
  1. BlueTooth Mobile ( Cell ) Phone Software
    By AMC 96 TE Magna in forum Wireless Communications
    Last Post: 03-23-2006, 07:44 AM
