I take it back...I lost all my plugin main buttons ...APOI, iGuidance, Audio Properties, RadioShark...
And I'm having a hard time restoring them.
I added them thru the plugins menu, but they don't show back up!
Had to go back in and add them thru button config setup
How bout adding a setting/button for that in the navigation settings menu, so each one can customize this?
I have mine set a 90 on my home pc for testing. I'll check the sound level in my car later.
90 would bring the volume to 90% for both main and wave volume, this is very very loud on my PC, and would blow you away in the car... Open the windows mixer and see if both levels are raising properly... Made the wave is not being controlled on some making the value need to be higher or something...
david
With me it sets however the Volume then on maximum and not to the before stopped value! :-(
David, I'm having an issue with importing music.. I just updated from 1.2 and haven't added music in a long time but I'm going to Tools -> Library -> Import then I click the source folder, then destination folder and then it seems to import perfectly fine. It copies the music to the correct directory, but the albums do not get added to the library.
If I go into the library and click on albums and hit play now, The total # of songs equals the actual amount of songs, but I cannot see any of the new albums in the library. I don't think I'm doing anything wrong as I've added songs in the past with no problems. Oh and if I rebuild the library it rebuilds perfectly and the albums do show up, it just happens when importing.
Also I think I remember reading once you said we can copy files manually from windows explorer and Centrafuse would add them to the library? If thats true could you explain how you do this exactly? Just copy the files while Centrafuse is open?
1991 Camaro Z28
2004 Acura TL
you would just hit Windows and minimize Centrafuse, then copy to any of your music folders...
I will check, this should be working... What happens is when you import it just copies the files and the same process as copying in windows should auto import...
I will check...
david
