Results 1 to 10 of 10
Thread: Bad sound when buffering radio on Infill
    Oct 2007
    Hello!
    I'm having some issues with the radio on my infill. If I use the buffer radio option the sound is really bad like a 56bit mp3 file. If I turn off the buffer, sound becomes great. Anyone else having the same issue or a way to solve it? This one time a while ago, the buffer sounded ok.
    Edit: added a video: http://www.youtube.com/watch?v=x8FrG7ylD1U
    First the buffer is on, then off, then on again.
    VENDOR - Centrafuse veetid's Avatar
    try to lower your line input from the Centrafuse mixer, if it is too high the sound will be a lot worse...
    I would take the line input all the way to the lowest possible value...
    david
    Oct 2007
    Quote Originally Posted by veetid View Post
    david
    Tried it all, even with line at 0 it is the same. The line volume does not change a thing when in buffer mode.
    Quote Originally Posted by eliaz View Post
    you would adjust under Mixer/Levels on the far right "line-in", move this down all the way towards the bottom...
    david
    Oct 2007
    It is not a too high volume issue on the "in" side. The sound is not distorted, like the volume was too high. It sounds like a really low bitrate mp3 file. Terrible. If I not use the buffer, the sound is just fine. I would really like to use the buffer option, but won't sacrifice crappy sound.
    I tried your suggestion but no luck, even with the "line-in" at 0, nothing happends. I tried restarting both centrafuse and the Infill.
    it records at 44100 in PCM wav...
    I will see what I can do... sounds fine on my Infill, but I might be able to notice really...
    david
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    If changing the line-in level isn't affecting at least the volume, the you're adjusting the wrong slider.
    What you can try is adjusting the RECORDING volume of the line-in in windows mixer (open mixer -> options -> properties -> recording -> ok : you should get another set of sliders now!).
    David, are you sure the cf sliders affect the recording part of the sound card?
    Joachim
    they should adjust the recording section, all the sliders on the right hand side in Levels section of the Mixer, it is is working correctly with the sound card...
    that is right, if adjusting the levels does not change the at least the volume, it is the wrong slider...
    try with buffer mode to go back to windows and use the windows mixer to adjust and see if you can make the sound correct...
    david
    also, do you have multiple soundcards on this system? I do have a current issue if multiple sound cards instaleld it might be adjusting the line-in on the wrong card, I am working to fix this....
    david
    Oct 2007
    I have found a solution to the problem! Thanks for helping me out guys!
    I opened windows mixer and muted "mic in" though it was muted on the "out side".
    Then the sound became perfect. However the radio volume worked, when i adjusted the "recording" slider.
    The "line-in" slider in windows mixer was greyed out, so I could not adjust it.
    (This also may explain that I could not adjust volume in CF.) It stands at about 70%.
    This means that the "recording" slider has to be at the very bottom to get a decent volume. Any way to make the "line-in" slider work?
    I'm using Infill G4 with onboard sound card, no usb card. Newest Xp drivers.
  1. Replies: 6
    Last Post: 05-19-2005, 08:59 AM
  2. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 07:08 AM
  3. Bad sound when USB>Serial adaptor connected
    By phil.45 in forum General Hardware Discussion
    Last Post: 08-27-2003, 09:13 AM
  4. Why does my audio sound so bad?
    By dudah85 in forum General Hardware Discussion
    Last Post: 06-21-2001, 08:11 AM
  5. Does this sound like a bad tape?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-28-2001, 09:27 PM
