Results 1 to 10 of 10
Thread: Cannot get Pharos/Microsoft GPS to work with CF
    Feb 2008
    Question Cannot get Pharos/Microsoft GPS to work with CF
    Before I buy CF, I want to make sure that my GPS works fine with it.
    It is a Pharos/Microsoft Sirf-3 USB GPS. It works fine in other software such as Streets & Trips but doesn't seem to lock onto any satellites in CF.
    Yes, I did set the baud rate to 9600...
    What can I do to make it work and will it work with CF at all?
    Thanks!
    May 2006
    Seattleish, WA
    People have said that there seems to be an issue with SiRF support... Flip it to NEMA and see how things go.
    :: Mark
    Feb 2008
    I change it to NMEA in CF but still nothing happens. Is there any other place for settings for the GPS?
    Elsewhere
    Try setting the baud rate to 4800,N,8,1 instead of 9600.
    Also, you may need software like SirfDemo that allows you to switch from SIRF to NMEA mode.
    If you open up a terminal window and view the output of the COM port for your GPS, you should see NMEA formatted sentences, similar to this:
    $GPGGA,123519,4807.038,N,01131.000,E,1,08,0.9,545. 4,M,46.9,M,,*47
    How about the Wiki?
    May 2006
    Seattleish, WA
    Quote Originally Posted by DarquePervert View Post
    For reference, here's SiRFDemo:
    http://www.sirf.com/free_demo.html
    And this may help as well... It's an app called GPSViewer:
    http://midiwall.com/bug/misc/GpsViewer1.5.zip
    :: Mark
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by midiwall View Post
    hey, midi:
    linky no work. Seems your website is down.............
    Leonardo Da Vinci
    May 2006
    Seattleish, WA
    Quote Originally Posted by greatwhite View Post
    hey, midi:
    Hmm... Are you just getting a 404 or? I can get to it from here, straight off that link and with a flushed cache. Try again?
    http://www.midiwall.com/bug/misc/GpsViewer1.5.zip
    :: Mark
    May 2007
    working now.
    Prob might have been on my end, I had a lot of stuff running the first time.
    Cheers
    Leonardo Da Vinci
    May 2006
    Seattleish, WA
    Cool!
    :: Mark
    Feb 2008
    Thanks! That worked for the GPS!
    Too bad CF won't read any russian mp3 tags. As a matter of fact, it doesn't even load half my mp3 files from DVD. Other than that, it seems like a great piece of software.
  1. How to get cf gps receiver to work in car
    By BIGGKATT01 in forum GPS
    Last Post: 09-19-2007, 06:32 PM
  2. Replies: 6
    Last Post: 11-21-2006, 07:07 AM
  3. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  4. Earthmate GPS don't work...help please
    By Skipjacks in forum GPS
    Last Post: 01-01-2005, 12:20 PM
