Results 1 to 10 of 11
Thread: usb peripherals work in winxp but not with centrafuse
    Dec 2007
    hi all - whats up with this?
    my mini-itx winxp incar pc can see the:
    1. usb GPS receiver (Haicom)
    2. usb vimroco mini webcam
    3. usb trinloc dab radio
    but these usb peripherals aren't seen by centrafuse 1.20
    any ideas welcome - thanks
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    First things first, install the latest version from here:
    Centrafuse 1.47 Update
    May 2006
    Seattleish, WA
    He might be running the trial Scott - I don't think 1.47 will run in trial mode?
    :: Mark
    Mar 2007
    Detroit, MI
    Quote Originally Posted by midiwall View Post
    Sure it will, no problem there I do not believe.
    Dec 2007
    just got back in form night shift - i run paid up version of 1.20 europe xle, will do the 1.47 update this arvo and see if centrafuse identifies the usb devices...
    May 2006
    Seattleish, WA
    Quote Originally Posted by smeesseman View Post
    Oh... Umm, then there are a couple of people that have come through the forum lately that may need that info. I thought that the versions after 1.20 were cobbled so that they had to have a license. With 1.20 targeted as the "download trial" version on the Flux site, that kinda' makes it look like that's it.
    It might be worthwhile to get a note to David that the "1.20 trial version" should just be replaced with a link to the latest version of CF. It'd probably help a couple of the folks sniffing around lookin' to buy.
    :: Mark
    Dec 2007
    no improvement
    updated to 147 but i still can't access any usb peripherals... don't say i need to become a c# programmer just to use my gps, webcam and radio...
    May 2006
    Seattleish, WA
    k, so lets focus on the devices one at a time. The GPS is probably the easiest.
    Which Haicom device are we talking about? ref: http://www.haicom.com.tw/product.aspx
    Does the GPS show up as a COM port? When you say you can get to it from Windows, what app are you using? If you launch that app from within CF (i.e., add it as an application, don't minimize CF and launch it), does it see the module? What happens if you _do_ minimize CF and launch the app? Does it see it then?
    :: Mark
    Mar 2006
    Colorado, but Canadian!
    Also make sure only 1 application is using the com port at any given time. So if GPS is on port 4 then only 1 program can access the program on port 4. There are programs that can split port 4 to ports 5 and 6 so 2 applications can use the same info at the same time.
    1.9in x 2.9in -- 47mm x 73mm
    May 2006
    Seattleish, WA
    Quote Originally Posted by 2k1Toaster View Post
    Good point!
    I think Xport is the most widely used...
    ref: http://curioustech.home.insightbb.com/xport.html
    :: Mark
  1. Does Winxp Boot Faster On Usb Hd/flash Drive?
    By emdzey01 in forum WinNT Based
    Last Post: 08-09-2010, 08:48 AM
  2. Centrafuse with Infill radio on ext. USB Audio
    By BulleDK in forum Centrafuse
    Last Post: 10-26-2007, 06:03 PM
  3. OBD-II devices in Centrafuse..Serial or USB?
    By NekkidRidr in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-02-2007, 08:54 PM
  4. SD, usb soundcard, and hidernation = no work
    By ranpid in forum StreetDeck
    Last Post: 09-29-2006, 08:18 PM
  5. Replies: 3
    Last Post: 04-09-2003, 10:48 AM
