I'm currently writing a Phidgets plugin if this is helpful for you.
Right now, CF isn't capable of embedding other information on the home screen, so you always have to switch to the plugin. This may change in a future release.
Hi all!
I'm planning my carPC installation and, having elected CF as my frontend software, I'm realizing that it does not have any support for external temperature sensors! How could be it ?!
Every car has such kind of information and I cannot believe that a CarPC installation could not provide the same information.
I've searched the forums and found a very old thread in which the argument was discussed (http://www.mp3car.com/vbulletin/cent...al+temperature), but as far as I understand no final statement was done.
Is there any chance that Fluxmedia (or someone else!) provide support for the most diffused temp sensors, like the K145 kit from KitsRus or FusionBrain ?
The temperature reading should be placed on the upper panel where it can be read anytime, like the clock. Could this be done within a (specialized) plugin?
Thanks for your comments.
Skinning to go... VisualDesigner2!
Thanks, Zorro, for your useful reply.
Maybe I'll have to embed the part of the plugin code which reads the sensor into the CarDash plugin I'm thinking of, if you'll allow it.
The CarDash plugin I'm thinking of should presents all the useful information normally displayed in a OEM system, like for example: time, date, ext. temp, int. temp, currently playing music, a few info coming from OBD, maybe tires info and eventually some GPS info (route, turns, etc, but I don't know if this is feasible). The plugin should have a few buttons to allow to go directly into some other functions of Centrafuse (Music, Navi, ecc.).
I had to think about the CarDash becuase of the limitation in the main menu of Centrafuse: it would be very cool if the main screen of Centrafuse could be personalized!
When do you think the Phidgets plugin will be ready ?
Thanks.
Diego.-
I will not release the source code for the plugin but I will add a bunch of CF_pluginData commands to it, so any other plugin will be able to read out the sensor / input data.
I think it'll be available for beta test somewhen next week.
Here's what it will look like (though one will be able to modify the skin easily using VD2).
Ich weiß, ich weiß!
Das ist schon lange her mit dem Englisch, naja..
Also ist das auch nichts für mich, hast du evtl. eine Idee wie ich ein Voltmeter integrieren kann?
(siehe hier: Fluxmedia-Forum-Thread)
Wenn ich mein DSATX endlich bekommen würde könnte ich ja das hier nutzen:
DSATX-Plugin
Ich hoffe nur das Zerach das Plugin fertigstellt und es dann später bei mir auch funktioniert.
FMode hat da auch ein sehr guten Vorschlag gemacht, das Problem ist das es wahrscheinlich niemand umsetzen wird. Und zwar die kommunikation mir dem DSATX, das man über Popup o.ä. das runterfahren verhindern kann (Tankstellenschaltung). Das wäre echt eine Erweiterung die viele nutzen könnten und ja auch viele haben wollen (inkl. mir).![]()
Ein Plugin schreiben?
