Results 1 to 6 of 6
Thread: Can send, but can't recieve email (gmail)
    _
    Mar 2004
    Little Elm, Texas
    I'm having an issue with the email functionality right now.
    I can successfully SEND email but I can't RECEIVE.
    I have it set to check every 120 minutes so maybe that has something to do with it? Perhaps I haven't give it enough time to download? I would assume it would download automatically once it's set-up, is this not the case?
    Should I just wait the 120 minutes (or just change the time frame upfront once then change it back)?
    Jan Bennett
    Constant Bitrate peijffertje's Avatar
    Nov 2005
    Netherlands
    Did you enable IMAP in your gmail account. It's under 'settings'.
    _
    Mar 2004
    Little Elm, Texas
    Yes, I'm able to download to my Outlook 2007 on my lappy.
    Jan Bennett
    Constant Bitrate b3tts32's Avatar
    May 2006
    Arlington, Tx
    Any resolution here? I'm in the same boat. I have changed all of my settings and ports to match the FAQ.
    VENDOR - Centrafuse Jan_RedGTiVR6's Avatar
    May 2008
    I'm able to do this just fine now. Not sure what I changed or what I did different, but it works. I guess it started working with a new install at some point.
    Jan Bennett
    Centrafuse Support
    VENDOR - Centrafuse veetid's Avatar
    it is the latest version, there was a problem with certificate verifcation with the gmail serve, it was fixed...
    david
  1. Gmail - New Email Count - Label & Indicator
    By W3bMa5t3r in forum RR Plugins
    Last Post: 02-27-2009, 01:45 PM
  2. Plugin Request - Email reading application
    By ankur in forum CF Plugins
    Last Post: 01-25-2007, 01:06 PM
  3. Feature Request - Email reading application
    By ankur in forum Centrafuse
    Last Post: 01-24-2007, 02:12 PM
  4. Answer a Riddle and win a Gmail account!
    By Shayughul in forum Off Topic
    Last Post: 08-27-2004, 09:12 PM
  5. send signal to RCA (not the screen)
    By lazynok in forum LCD/Display
    Last Post: 08-12-2003, 12:47 AM
