I believe CF uses a different media engine than SD.
Someone more in the know can chime in here.............
Ok moving from SD to CF and the sound seems to be alot clearer than sd is , my music seems sharper? , i am using a jl e4300 amp , and hippodac 24bit DAC to feed the sound in , is it just my imagination or is there a good reason for this?
my music collection is in WMA is that a good idea or should i use mp3? thanks
Leonardo Da Vinci
Leonardo Da Vinci
CF uses DirectX with it's own embedded player and codecs
David's using WMP codecs when possible. There are many posts here from him stating that WMP 10+ should be installed. e.g.,
WMA issues
http://www.mp3car.com/vbulletin/cent...ml#post1188076
The exception would be some video codecs, but that's not what tis thread is based around.
:: Mark
