Hi!
The Infill plugin does not seem to work with 2.0.
1. Radio does not work, volume controls does not work, not tilt or brightness. And when I press volume up or down in the main screen it adjusts speaker balance not volume.
2. Can only select "default" as soundcard in settings.
3. The 16k eq band at 800x480 resolution is only half visible.
4. Master volume slider will stay at bottom when adjusting it, however a transparent is visible.
Okay, good
Also wanted to add that the mute button does not work.
Keep up the good work! Great update
When will you release the fix for the infill plugin? It's killing me not having radio!
we are working on an update as quickly as possible to fix a bunch of various issues, including Infill...
david
