Did you by any chance mess with the date or time after installing?
I got my phone working in the new build today then I turned my system off when I went to use Centrafuse it says I have 0 days left on the trial I uninstalled then reinstalled it still says 0-30 days and the trial button is grayed out.
did you change any major pieces of hardware, check your date and time and make sure it did not get reset, if so set it back...
david
Thank you Lazyflip and David for your quick reply.
I feel so stupid I forgot that last night I clicked on the time in CF because the time was wrong it said I couldn't change it in CF so I changed it in windows time and date. After reading your posts I remembered I did change it and I changed it back this morning and it works fine thanks so much.
