sorry if this is somewhere blantant and i missed it...but is there any phone info anywhere? i've installed 2.0 rc1 and have synced my phone but all i get is the flashing headset in the top bar within centrafuse. the bt icon on my phone is white instead of blue...is this to assume that it's syncing? sprint treo 700wx fwiw
Jan Bennett
My opinion is my own.
thanks for the link - I'm trying to get ready for work so I didn't have much time this morning to look. I'll check that thread!
And I too use the 50 posts/page setting...![]()
Jan Bennett
The headset thing seems to be different from what I'm mentioning...mine is just flashing at the top. None of my contacts are coming over or anything.
Unless...
Is it wanting you to use a headset instead of a microphone? This doesn't make much sense.
However, I did have the 5MB limit notice come up. Not sure what that's about.
I wish I had more time to spend on this this morning and read up on all of the threads...maybe during work I'll have a few moments.
Jan Bennett
Mine would only allow a headset. It wasn't flashing, it was just there. The 5mb thing never popped up. Reason I sent you there is because the CF guys wanted some info back on the problem (I do really like those guys). Unfortunately, I went back to SD so I can't help them. You can't run SD and CF 2.0 on the same computer.![]()
You can Dan, but unfortunately you have to install SD second. The only reason I know that is because I wiped my HD about a week before CF 2.0 came out due to some serious driver conflicts I was having. Then, I ended up installing CF first and SD later. They both work.
@Jan: the 5MB limit is a limit of the trial version of the BluSoleil BT stack that comes with CF. The CF guys are getting the serial licenses from IVT (BluSoleil manufacturer) as we speak, and if you are a CF license owner, you'll be given a BluSoleil license to go along with it. Once entered, the 5MB limit will go away. Right now, if the 5MB limit comes up, a restart of the BT stack will start you over with the MB's.
I have the CF phone module working well with my phone. What kind of phone do you have? I too had some issues first, and even had the blinking Headset icon. What I did was delete my pairing between CF and the phone, and then initialized the pairing from the phone, as opposed to before where I initialized the pairing from CF's interface. Try that and see if you get different results.
The 5MB limit is just for these Beta/RC versions, this will be resolved once 2.0 is final...
The blinking headset means it is trying to connect to your phone, try to remove the pair and make it again from the phone, have the phone start the search and find Centrafuse... IF that is what you did, then try to search from Centrafuse and have it pair to your phone...
Then make sure in Settings\Phone that your default phone device is set to your phone and your paired device...
The current version does not have support for reading contacts, but you can add contacts manually for now... You should see it blinking the headset, then go solid to connect, it is just HFP support now so you get support to place outgoing calls, incoming call notifications, 3 way calling, call waiting, audio gateway support for hands free...
the dialed, received, missed calls all show up based on while using Centrafuse, and you can manually add contacts, import with vCard, or do an OBEX push to send contacts over...
we are adding contacts and SMS support, but getting all the HFP stuff working first...
david
