Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 47
Thread: Phone echo
  1. #31
    Low Bitrate Salmizar's Avatar
    Oct 2007
    Ontario, Canada
    slashdot,
    The caller says something. It plays from the speakers of the carputer, the mic then picks it up and plays it back to the caller. That's the echo.
    It doesn't return because the mic on the phone is far enough away from the phones speaker so that it doesn't pick up the returned audio and loop.
  2. #32
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Why cant the sound patterns be compared to the ones that are being transmitted to the line out device then eliminated if they are picked up on the mic or line in device. Plus just not transmit what is being said in to the microphone through the line out device.
    Maybe easier said than done but it seems like this could be done with some creative thinking.
    New Age Garmin - Skin for RR
  3. #33
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    im geting on trying to deal w/ echo too.
    software wise i can reduce echo on windows easy! as lond as I can get 2 separate streams... do few recording and substracting wave info from previous recording and you have more or less no echo, but quolity gets reduced to as in wave we not alaways can figure to what level to cut the stream
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  4. #34
    Jan 2008
    Quote Originally Posted by Salmizar View Post
    slashdot,
    Ok, so why echo exist anyway with the car speaker muted too?
  5. #35
    Jun 2007
    New York
    because test was not done properly. Try muting spekers on both side of conversation. If echo still exist then you are runing on slow system. I did test run on my dev desctop with headphones and had no echo i was using BluSoleil alone w/o CF connection was established between my desctop and cell phone located few feet away but far anough for us not to "see" sound delay.
  6. #36
    Low Bitrate IssaquahWA1979's Avatar
    Oct 2009
    Issaquah Washington
    any updates on this?
    Custom Built Intel D510MO, 2GB RAM, M4-ATX, Elios 15" TS on custom mount.
    System installed into 2005 Dodge Ram 3500 Cummins Diesel 4x4.
    I can provide Custom fabrication for mounts or installation please contact me. CNC Machining and Powder Coating
  7. #37
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    If you have a realtek based soundcard, there are software side options to eliminate the echo. I know for a fact it works on the Intel D945GCLF2 board.
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
  8. #38
    Jun 2007
    New York
    what relatek chip and soft u uning?
    I have relateck on my dev comp, it has Virtual Mic Amplification +20dB boost but no ech cancelation
  9. #39
    Nov 2005
    Toronto, ON
    I'm using the D945GCLF2 board and the included Realtek Driver pack on a Windows 7 Ultimate install. Go Control Panel>Hardware and Sound and you should see Realtek HD Audio at the bottom of the list, open that and click on the microphone tab. The options are in there.
  10. #40
    Jun 2007
    New York
    i have other MSI board but 945 chipset too and reealteck but nothing is there... maybe we need new driver. But toabr runs XP.
    Let me see if driver has new feature them lots of things are made easy. Although not in all cases
