Do you have advanced settings turned on?
I thought I saw a post about this this morning, but I don't see it now...maybe it's hidden in another thread?
I've noticed that there's no more config for XM in the settings any more. Is this by design or just a simple oversight?
Just wondering!
Keep up the good work guys!
Jan Bennett
How do toggle that setting on or off?
My carpc worklog
Yeah... this is getting to be fun.
There are two ways, and they're buried in the release notes (ref:Centrafuse 2.0 RC1)
Settings are now defaulted to show the Basic Settings mode. Advanced Settings can be enabled in 2 ways.The "8 second" thing can be weird... For most of us using touchscreens, that's not a viable option since we have "automatic right click" enabled, which brings up the windows right-click menu after 3-4 seconds. You'll need to turn that off, or use the command line option in the startup shortcut for CF.
To enable Advanced Settings temporarily, hold down the "+" button in the Main Settings Screen for 8 seconds.
To permanently enable Advanced Settings, similar to older version of CF, pass the -advsettings command line option when starting Centrafuse.
:: Mark
I know I'm a little late, but thanks for passing that information along!
I'll be adding the command line option when I get a chance.
Jan Bennett
