Same thing for me... using instantradio fm,
Printable View
i guess its the bluetooth is not support with the new bluetooth software, but i have a rocketfish usb bluetooth adapter... it came with the keybaord mouse combo wors great withthe supplied software. btu not with the one u guys hace the bluesoil or how ever u spell it.
Same here I'm afraid; 100% CPU usage and I am finding almost all features are hanging e.g. random play of all tracks just ends in the busy indicator on the media screen foreever; selecting rebuild library from the tools menu just shows at empty pop-up dialogue etc... I am using 800 x 600 resolution and I upgraded my previous 1.4 XLE install.
I upgraded from 2.0 RC1 to RC2, but now every time I run centrafuse it close right when I click on I Agree.
I tried the same installation on my home pc, then same thing happens.
Help......:confused:
David, maybe this will help. As you can see from my previous posts in this thread CF RC2 on my machine was crashing every 15 minutes. I had everything disabled (Phone, Radio, etc.) but Nav. So I disabled the nav as well and the system was stable for several days!!! No crashes, nothing hangs. So, today I enabled the nav and it wasn't working right away. I had to reboot the PC in order to get it to work. Finaly, the nav was working, but, after a few minutes, the system crashed. I created two system reports: one before I enabled nav and the second one after the crash. I am at work right now, so I'll upload those reports tonight. The nav worked fine in 1.47 and RC1.
Hope this helps.
AK47
thanks for the logs...
did you have TMC enabled in the NAV?
we have received another update from Destinator, the NAV was beta versions as we get updates from them...
also there were major issues in RC2 with the installer, RC3 will be much better...
david
I had to un-install CR2 and use CCleaner.com to clean the registry.
then a reinstall CR2 did the trick.
all working fine.:deadhorse:
I just installed RC2 and, well, it's not going too good.
The program starts with no problem.
When I go through the setup "wizard", I can't set anything and actually have to use the Task Manager to close Centrafuse. The windows that come up to set, say, the music directories, get "stuck". If I click any of the buttons on the window, they "light up", but don't do anything.
At the main screen, clicking any of the buttons only causes them to "light up" as well, but again, nothing happens.
I'm running Vista Home Premium 32bit on a AMD64x2 system with 2gigs of ram and a 512meg video card if that helps.
