Results 1 to 10 of 13
Thread: Bluetooth Issue
    Apr 2008
    Bluetooth Issue
    I'm having some blutetooth issues. Every time i start the computer up and open Centrafuse for the first time i can pair Centrafuse with my phone (Helio Ocean) and even make one call from Centrafuse before Centrafuse drops the bluetooth connection. When i make the call from Centrafuse while my phone does respond and call the number i can't hear the audio through the computer.
    I've never been able to initiate the pairing from my phone. My phone sees the device but when i try to pair them it ask for a pin, i enter 0000 because that always worked before and it just says invalid pin.
    I'm currently still using the evalution copy of cetrafuse. Are these issues due to the evaluation copy's lack of a Bluesolei license?
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Quote Originally Posted by Moc5085 View Post
    Turn "Log Events" on in phone settings, reproduce the issue, generate a system report (in advanced settings) and post the generated .flux fille, from there I can see what's happening...
    Apr 2008
    how do i turn advandce settings om
    I thought i was computer literate but i have no idea what "pass the -advsettings command line option..." means. How do i do this; becuase holding the plus button down is getting me now where.
    VENDOR - Centrafuse veetid's Avatar
    right click the Centrafuse shortcut on your desktop or startup folder, and change the target to this...
    "C:\Program Files\Flux Media\Centrafuse\centrafuse.exe" -advsettings
    david
    Mar 2007
    Detroit, MI
    just re-read that first post and noticed you are pairing your phone each time CF starts? You should only have to do that once... I'll take a look at your log when you can get it posted...
    Apr 2008
    i've activated the advanced settings but i still dont see the option to generate a phone log report in the phone settings.
    _
    Mar 2004
    Little Elm, Texas
    On the phone settings page, the third setting down on the right side should be a yes/no setting to enable error reporting for the phone.
    Do you not see this?
    Jan Bennett
    Apr 2008
    yes i see, the log events button and I've selected yes. How do i generate a system report?
    _
    Mar 2004
    Little Elm, Texas
    Scroll to the very end of the settings list and you will see an option to 'Generate a System Report'.
    Select that menu item then select 'Set-up'. You'll be prompted to save the report to a different location, pick yes or no and there ya go!
    Jan Bennett
    Apr 2008
    I've activated the advanced settings but 'Generate a System Report' still dosen't show in the settings list.
  1. Bluetooth problems their solutions
    By Clintebb in forum Bluetooth Hardware
    Last Post: 12-26-2007, 09:03 AM
  2. Bluetooth Issue
    By tn6478 in forum Bluetooth Hardware
    Last Post: 06-24-2007, 12:21 PM
  3. Replies: 13
    Last Post: 03-09-2006, 05:29 AM
  4. Bluetooth Trackball
    By Caelric in forum Input Devices
    Last Post: 01-13-2006, 12:29 PM
