Results 1 to 5 of 5
Thread: NAV issue?
    Jun 2007
    Chicago
    NAV issue?
    I have the BU-353 and everytime I try a baud rate higher than 4800 it doesn't work. Any suggestions?
    May 2006
    Calgary, Alberta
    http://www.usglobalsat.com/downloads...S_win_v2.2.pdf
    These are only a few simple steps that you need to follow before using your USB GPS receiver:
    • Install the USB driver and onto your laptop from the included CD-ROM or download the files from our web-site
    www.usglobalsat.com
    • Plug-in the GPS receiver into your laptop.
    NOTE: From within your mapping, or navigation software (including the supplied GPS Information utility), you will
    need to manually configure the selection of the COM port to what was assigned to the GPS receiver so that proper
    communication between the GPS receiver and mapping program can occur. Most all software requires that you
    manually configure the COM port setting for any GPS device you use.
    IMPORTANT:
    1. You must change the default rate setting of your mapping software ‘s Baud Rate to 4800 if this is not currently
    set as such otherwise GPS data cannot be received.
    2. Set Baud Rate 4800, Data Bit: 8, Parity: None, Stop Bit: 1, Flow Control: None
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jun 2007
    Chicago
    No fair....who reads instructions?!
    Thanks!
    Elsewhere
    Quote Originally Posted by ekaz View Post
    Those of us that like our equipment to work.
    How about the Wiki?
    Jun 2007
    Chicago
    I had it working, just wanted it working faster....
  1. Another Lilliput issue, Maybe
    By djmickyg in forum LCD/Display
    Last Post: 05-04-2008, 06:29 AM
  2. M4-ATX Power On Issue
    By PacketSniffer in forum Power Supplies
    Last Post: 04-24-2008, 11:00 PM
  3. Lilliput 7" into 350Z without Nav Pocket?
    By NegativeFX in forum Newbie
    Last Post: 09-19-2005, 09:34 AM
  4. windows not displaying on factory nav screen
    By brobins75 in forum LCD/Display
    Last Post: 09-10-2005, 04:08 PM
  5. E46 CarPC with NAV
    By Hark in forum Newbie
    Last Post: 06-16-2005, 11:31 AM
