Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: CF 2.0 RC4: Bugs / issues / suggestions
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I figured I'd be the first to start this one.....
    So far RC4 seems to have fixed a cr@p load of issues I was having before, except one.... infact it seems to do something worse. On RC3 when I would leave CF on then go into hibernation, but when coming out of hibernation I would get nothing but a black screen and could not do anything. On RC4 its diffrent, instead when I come out of hibernation I see the Windows welcome screen, but thats it.... even if I hit log on, it stays there. I can see all the ballons from the bluetooth not being registered, the network connection and what not. When I look at the HDD light, I can see its loading up something, but the whole time the welcome screen is stuck.
    Can someone please help!?!?!?!?!
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    May 2008
    I have a loading icon in the center of the screen most of the time...This wasnt an issue before with XLE and RC3. Dont know why this time...
    Jul 2007
    Miami
    Quote Originally Posted by drwpilot View Post
    OOPS, I also forgot, I have this issue too sometimes.... it especially will do it with the web browser and sometimes with the XM and HD radio.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    Apr 2007
    USA
    Yeah I see that loading icon (spinning circle animation) frequently. Sometimes it goes away after a while, sometimes it doesn't.
    Oct 2004
    volume issue
    one issue i have seen is that coming back from hibernation. the volume will be down i will have to pause the music playing and un puase it to come back or turn volume back up.
    May 2006
    Seattleish, WA
    I finally loaded up 2.0 RC4, coming from 1.47. I waited a while figuring that a lot of the issues that come with new CF releases would be flushed out. I should have waited a while longer...
    This was an upgrade, NOT a fresh install.
    1. The Sat radio module isn't reloading after hibernate. This is the same issue that I've reported a couple of times against 1.47. The symptom is "no audio after restore from hibernate when hibernate happened on XM screen". The fix is that you have to exit the module, then go back in. When you do this, you see the "loading spinner" (on 1.47 you saw "Loading...") and then Sat comes back.
    2. When you enter the "Soundcard I/O" choices dialog for the Recording and Playback choices in Sat radio, the headings on both screens are "Select Line In".
    3. Actually, what's the point of making Recording and Playback choices in the Sat radio module?
    4. The BlueSoleil stack installed but it didn't setup. It didn't unhook the stack I was running (stock Windows). This has a number of side complications since CF is locked to BS.
    5. For those folks that don't use the -advsettings command line switch, how about making the "plus sign trigger" toggle sticky for the life of the CF instance? i.e., user sets the toggle, and it sticks until CF is restarted. Having to keep turn that thing on is a pain.
    6. Why is there a menu of choices on HOW to exit _PLUS_ an additional "Are you sure"?
    7. The installer didn't keep my old settings - it just plowed through and wrote over everything. SOB that's annoying. I've been mumbling "Start with a solid core" around here for over a year - someone should start listening to those words.
    8. There are tons of little things... I think other folks have mentioned all that I saw. The advance graphics stuff is slow; tag scanning on WMA's is weird (that's NEVER been right); media playback can be a CPU hog and slow down the UI; when not using "-advsettings" there are blank lines in the options menus; 3 out of 5 times on exit, CF was left "running" as a windowless process(I had to kill it through task manager)... And I haven't even tried much past XM and MP3 playback.
    It took me so long to get everything to work that I drained the battery in my car to the point of needing a jump to start it.
    This is becoming a real PITA.
    :: Mark
    May 2006
    Seattleish, WA
    Quote Originally Posted by johnk View Post
    Do you have Web enabled? If so, and if you leave it on a web page that auto-refreshes (CNN, traffic, weather), CF will spin that thing while it reloads the page - no matter what the current CF screen is. It's been doing that since the late 1.4x days.
    :: Mark
    Apr 2007
    USA
    Quote Originally Posted by midiwall View Post
    Yeah, I don't like that confirmation either. I think it would be very rare to accidentally choose one of those shutdown options.
    Apr 2007
    USA
    Nope (no Internet connection in the car).
    May 2006
    Seattleish, WA
    Actually, I don't mind the conformation - I've hit "BACK" too many times and would have exited CF without it. It's actually the option list that drives me nuts. There are button options for each of those.
    Hmm... okay, not that then!
    :: Mark
  1. V1 Virtual Display v0.9 bugs / suggestions / ideas
    By zPilott in forum Software & Software Development
    Last Post: 04-12-2009, 11:41 AM
  2. EU version, some bugs, some suggestions :)
    By Artificial in forum StreetDeck
    Last Post: 05-25-2007, 08:41 AM
  3. Replies: 5
    Last Post: 05-21-2007, 11:53 AM
  4. Centrafuse RC4 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-18-2006, 04:10 PM
  5. RC 3.1 findings / suggestions
    By holybob in forum Centrafuse
    Last Post: 09-27-2006, 01:06 PM
