Results 1 to 10 of 16
Thread: Loading...
    Aug 2005
    Loading...
    Anyone else have a pretty large dleay when loading Centrafuse?
    I mean windows is booted. You click Centrafuse. The time before you actually see the Centrafuse "Loading" Screen?
    All other apps are isntant.
    Mar 2006
    Colorado, but Canadian!
    XP or Vista?
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2005
    XP. My XP is pretty hacked to be light and fast. I actually just started making a new install and its still the same.
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Yes, mine does that. Between 5 to 10 seconds. I too am runing an nlited XP (Pro).
    It's not an issue for me as I use hibernate, so it only takes me 15 seconds or so to start music from when I turn the key.
    I installed my carpc into my pet Kangaroo, mate.
    May 2006
    Seattleish, WA
    Quote Originally Posted by SKiTLz View Post
    Anyone else have a pretty large delay when loading Centrafuse?
    All other apps are instant.
    Yeup... And it got longer with 2.x. These days, I don't even get the "loading" mouse cursor telling me that something's happening. It's there initially, then CF is clearing it before it puts up the first banner.
    I've tried to double-load it a number of times thinking that nothing was going on.
    :: Mark
    Apr 2007
    USA
    I'm on XP (using an Infill G4) and it probably takes about a minute for CF to load.
    I would use Standby, but since RC4, CF is broken when resuming from Standby or Hibernate.
    Aug 2005
    Ok so I'm not the only one.. Good.. I ran out of stuff to tweak..
    Looks like I'm not the one that needs to be tweaking.
    Nov 2006
    If you remove any plugins that you don't use from the plugin folder in the CF directory, your opening time will decrease. Email was the biggest time saver for me...
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Centrafuse loads up a lot of memory intensive functionality, so it can take a bit naturally, especially from a boot. Consecutive runs of CF after the first should load much faster... I will look to see if theres something that can be done to make the splash screen come up quicker...
    Have you tried loading it on a normal version of xp? Any difference?
    Quote Originally Posted by midiwall View Post
    Will try to see if we can bring up the splash screen right away
    Quote Originally Posted by johnk View Post
    Is it taking a full minute? I had some of your logs from before and they were all around 25-30 seconds, which is almost normal on a first run after boot on a g4. if its takin' a full minute, post me up a log so we can see where the delay is...
    May 2006
    Seattleish, WA
    Quote Originally Posted by smeesseman View Post
    Umm... what? Are you saying you're banking on Windows caching to reduce the subsequent load times of CF? In the real world Scott, there's a shutdown after exit... Any cache is gone.
    The only time I'd be exiting CF and then reloading without a reboot in-between is trying to get other stuff installed around CF. Once the system is running, then I'm either hibernating or shutting down.
    At least stop resetting the mouse cursor... And maybe an animated load indicator to entertain us.
    :: Mark
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
