+ Reply to Thread
Results 1 to 8 of 8
Thread: Making centrafuse start when windows starts
    Banned
    Aug 2006
    just recently bought centrafuse XLE and i didnt select to run as system shell when i first installed it so i could work on the system...but now that its done i want it to run when windows starts up but cant find the setting for it now that it is installed.
    Edit have version 2.0 RC6
    Oct 2006
    i'm not aware of the setting on centrafuse, but theres alternative, which is creating a shortcut to centrafuse and place it into the startup folder (drag/drop)
    Vendor - Qube colin's Avatar
    Dec 2006
    All that does is change a setting in your registry.
    In fact I believe there's a post (possibly sticky) on this forum about it.
    From trap17.com (first google result):
    Changing the default shell (all users):
    1) open regedit (start menu > run, and type in regedit)
    2) go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon.
    3) Change Shell from explorer.exe to the new shell path e.g C:\Litestep\litestep.exe
    4) log out and log back in.
    Changing the default shell (only current user):
    1) open regedit (start menu > run, and type in regedit).
    2) go to: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Winlogon.
    3) add a new string value (Edit > New > String Value) called shell. and set the value to the path of the new shell e.g C:\Litestep\litestep.exe.
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    you can turn cf on as shell in the general settings, you have to enable advanced settings to get this option to appear... (hold down '+' button in settings for 6 seconds until popup appears)
    Banned
    Aug 2006
    thanks just what i was looking for
    Constant Bitrate ivanmx6's Avatar
    Dec 2006
    Dorset, UK
    If you don't want it to run as a shell you could use the new Centrafuse Loader.
    See here: http://forums.fluxmedia.net/miscella...se-loader.html
    Oct 2009
    Sorry to bring up and old thread.
    I have centrafuse running as the system shell. I forgot to activate windows, and when I did, Centrafuse is telling me that my trial is expired, even though I downloaded my activation file the other day. Now I am locked out of windows.
    How can I run the windows shell now? I hit control alt delete, start a task...but I am not sure what I need to select to bring windows desktop up.
+ Reply to Thread
  1. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 09:31 PM
  2. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  3. How do i start a program when windows starts its shutdown rutines
    By darkwingduck in forum General Hardware Discussion
    Last Post: 12-10-1999, 07:28 AM
  4. Making Winamp LCD plugin start automatically
    By RobRoy in forum General Hardware Discussion
    Last Post: 11-06-1999, 01:50 AM
