Results 1 to 10 of 15
Thread: DVD button will not work
    Mar 2008
    Australia
    When I click the DVD button on the main menu, it gets high lighted and makes a click sound but it will not load up the dvd menu. Centrafuse does not hang and everything else works. Version is 1.47 with Windows Media Player 10 and no codec packs installed, running on Tinyxp. Previous versions of Centrafuse worked fine. Here is the error.log
    7/9/2008 9:43:52 PM
    Class not registered
    at System.Windows.Forms.AxHost.CreateInstance()
    at System.Windows.Forms.AxHost.GetOcxCreate()
    at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
    at System.Windows.Forms.AxHost.CreateHandle()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.AxHost.EndInit()
    at centrafuse.dvd.buildControls()
    at centrafuse.dvd..ctor(ICFMain pForm)
    at centrafuse.main.changeLocation(CF_Actions mode)
    Aug 2007
    New Orleans, LA
    depending on the version of TinyXP you're running, WMP was stripped from the OS. This includes all the little dependencies and calls all over. If you instaled WMP to get it back, it may not have restored all the files, dependencies, etc. Give it a shot with a normal install of Windows, not a stripped verion like TinyXP.
    Crawdaddy
    1991 Chevy Suburban 1500 w/SBC 350
    2005 Saturn ION 2 sedan
    Suburban Worklog
    "A local New Orleans man says his socks are finally dry..." -Tom Tucker, Family Guy
    Apr 2007
    USA
    To confirm if it is a WMP issue, it would probably be easier to just try playing the DVD in WMP.
    Mar 2008
    Australia
    The DVD does play in WMP but will not in CF. DVD did work in version 1.20. I have had 1.47 running for a while now and I haven't checked the DVD function until now.
    tinyxp + wmp10 + CF 1.20 = dvd working
    tinyxp + wmp10 + CF 1.47 = dvd not working, so obviously something in CF has changed. Probably now dependant on another file i do not have. It works on a full xp install but I do not want that.
    One thing I have noticed is that after I press the dvd button and nothing happens, I can click anything else once and it comes up, except for the exit button. I have to press it twice for it to work after pressing the dvd button.
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    I'm having the same problem. Works fine in WMP11 and VLC, but not with CF.
    Clicking the DVD button does nothing except mute the playlist.
    Cf error log:
    13/07/2008 4:54:10 PM (54:10:42)
    Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
    at System.Windows.Forms.UnsafeNativeMethods.CoCreateI nstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
    at System.Windows.Forms.AxHost.CreateWithoutLicense(G uid clsid)
    at System.Windows.Forms.AxHost.CreateWithLicense(Stri ng license, Guid clsid)
    at System.Windows.Forms.AxHost.CreateInstanceCore(Gui d clsid)
    at centrafuse.dvd.e()
    at centrafuse.main.a(CF_Actions b)
    I installed my carpc into my pet Kangaroo, mate.
    Mar 2008
    Australia
    Are you using a full version of windows nislo?
    Nov 2006
    No, I'm using an Nlited XP.
    It has a complete WMP10 installed though which can play dvd's fine outside of CF. There must be something CF depends on that is removed by nlite.
    The guys at Flux would obviously know what CF calls. It'd be good to know what that is...
    Mar 2008
    Australia
    Yeah I guess we are pretty much stuck until we can get some more info. I can rule out a codec issue as i have tested the same one on my tinyxp and a full version xp, tiny wont play dvd in centrafuse, full version does.
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    we're actively working on the dvd issues... they do have to do with codecs, and what hardware those codecs run on. It's very tricky stuff, hopefully after we can spend more time on this we can finally find out why some users experience so many difficulties with cf dvd playback...
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Quick question smeesseman. Are you guys using the dvd functionality in directshow or are you using a third party dvd solution. I remember David saying something a long time ago about moving away from the like mswebdvd/directshow and using a third party mpeg2 decoder and dvd playback api/sdk.
    We are, will have and forever will be...
    But not tommorrow!
  1. Power button won't work when laptop lid is closed
    By scotty562 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-22-2006, 11:25 PM
  2. Replies: 2
    Last Post: 02-13-2005, 07:05 PM
  3. DVD player work in vertical?
    By alia176 in forum Off Topic
    Last Post: 01-29-2004, 05:10 PM
