Centrafuse 1.2 and Nokia PC Suite
Up to now, everything has been running smooth, got bluetooth keyboard, phonecontrol working ok. But when I try to connect to the internet using Nokia One Touch Access, I get the following error: "Failed to connect to the network! The modem may be used by another application or the modem may not be configured properly"
The connection works fine within windows however. Nokia doesn't boot on startup and i've confirmed phone is paired within centrafuse.
Does anyone have any ideas?
nevermind. Found out it appears the phonecontrol and pc suite don't work simaltaneously over bluetooth
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
