+ Reply to Thread
Results 1 to 10 of 14
Thread: Subaru SSM - Working!...almost
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    To those interested in getting CF working with Subaru SSM, I've posted a thread on the fluxmedia forums with a rundown of how I embeded and configured a small program into CF until a plugin can be created. It's nothing groundbreaking, but it does get us showing some SSM data for now.
    I installed my carpc into my pet Kangaroo, mate.
    VENDOR - Centrafuse veetid's Avatar
    nice work...
    the new 2.0 SDK will be ready very soon, and it includes graphics files, and examples in C#, VB.NET, C++, and Delphi... Delphi might come in a later release, but the other 3 languages for sure...
    they are commented and easy to understand examples that will help developers create plugins and understand the SDK easier...
    david
    Nov 2006
    Excellent.
    That SSM program is written in .net which should make it easier. That's the theory at least.
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Sick, I'm working on getting MUT-III for my evo with my dash. If only ecuflash could be embedded ;-]
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Dec 2006
    Center of the Universe
    - The program is called Tree Hugger /Lumberjack.
    http://www.codeplex.com/ssm/Thread/List.aspx
    - Actually the window should be called Tree Hugger; mainform is only used when the COM port is set to "Mock". Mine uses COM3 port (COM5 is for GPS)
    - It is best used with a Tactrix Cable. Different world areas use different tuning, here in North America we also have Cobb Tuning which sells you a programmer and an OBD-2 cable. My CarPC did not work with the Cobb Cable; my laptop did. I ended up buying a Tactrix Cable.
    http://www.tactrix.com/
    - The Tactrix Cable does work with turbocharged Subarus and Mitsubishi EVOs.
    I display
    Boost;
    AFR for my "lean burn" periods when I stray a wee from 14.7;
    Knock Correction (if consistently negative then is very) bad)
    Coolant Temperature (Subarus do not have oil temp sensor: FAIL !!! ;
    Mass Air Flow Sensor (On Subarus, the grams/second reading from MAF happens to have an almost 1:1 ratio with the wheel horsepower (add 20% for crank horsepower) and I am pro-tuned, so I know my true BHP and WHP and my numbers are close. Other people use Engine Load (g/rev) but that is a funny number.
    % Throttle
    - The parameters are selectable; just tedious work in figuring which one you have to select.
    - Awesome program, but I would improve the parameter selection and the contrast for the parameter name display.
    - There is absolutely ZERO need of a plugin. This thing embeds swiftly and works flawlessly.
    Nov 2006
    Mmm that interesting, because my treehugger window name is mainform even with the comport selected...
    I ended up using the cable from Evoscan (it's still the Openport 1.3 cable though), so exactly the same as Tactrix, except it was cheaper with cheaper shipping (having come from New Zealand rather than the US).
    After using Treehugger for a while, I agree that there really is no need for a plugin, however it does need some work on parameter selection and the display like you mentioned. I'd like to add Min and Max displays for each paramter in the same manner as RomRaider too.
    Newbie nemoid's Avatar
    Jan 2008
    914.ny
    looks good. I'm very annoyed this doesn't work with my ELM327 device. I really don't want to spend $170 for a tactrix cable
    Dec 2006
    tactrix 1,1 is just 100 dollars
    I would not mind a shift light. One for say upshift and one for downshift, since the program can display what gear you are in.
    What precisely is your problem with the program ?
    Jan 2008
    914.ny
    I haven't found anywhere that's selling that cable. Or one that has it in stock.
    As for the problem (if you are talking to me), it doesn't connect to my ECU. It errors out when I attempt to connect. Apparently ELM327 doesn't support SSM.
    Dec 2006
    Yeah, what they did was ditch OpenPOrt 1.3 or whatever it was and upgraded to version 2.0 which is more expensive but it is not what we really need - it simply is too much - (data logging to a microcard for instance)
+ Reply to Thread
  1. Subaru Impreza WRX Skin
    By Pez Are Yummy in forum RR Skins
    Last Post: 10-31-2007, 11:03 PM
  2. No USB Devices Working Out of the Blue
    By tbird2340 in forum General MP3Car Discussion
    Last Post: 10-17-2007, 12:21 PM
  3. -DisableWindowHooks not working - 1.1.0.0
    By Indy in forum StreetDeck Bug Reports
    Last Post: 07-31-2007, 09:40 AM
  4. SPV M700 / HTC P3600 not working with Phonecontrol
    By Tracert in forum PhoneControl
    Last Post: 07-13-2007, 11:16 PM
  5. Anyone currently working with 18f2550
    By lez in forum General Hardware Discussion
    Last Post: 11-03-2006, 08:44 AM
