Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
Thread: Sygic Drive in Centrafuse?
  1. #31
    Jun 2009
    London, United Kingdom
    So just before I decide to purchase Centrafuse, can sygic work fully integrated yet? As I want to use sygic instead of the destinator for it's graphical benefits, rate of updates and a generally cleaner GUI. But obviously this only works well if it's fully integrated!
  2. #32
    Aug 2008
    i use sygic fully integrated. there even exists a plugin for it and a special version for CF with muting of cf.
    so go ahead and use it
    if you need help for integrating i can help
  3. #33
    Feb 2009
    Finland
    Where is this plugin? Could You give a link?
  4. #34
    Aug 2008
    http://www.carputer.it/showthread.php?t=8773
    here you find the thread .... but you have to be registered there i guess. (i am)
  5. #35
    Feb 2009
    Finland
    thx
  6. #36
    Jun 2009
    I have Centafuse and Sygic Drive XP RC12 with latest 2009 maps... How do I get them working together? I understand english fine but other languages aren't really helpful for me :S
    I've downloaded the patch app thing and ran it, showed it the Sygic directory and it came up with some dialog but got no idea what it said...
    Opened Centrafuse and nothings changed?
  7. #37
    Jun 2009
    Ok i ran it again, same thing, directory etc and this time it's given me a Sygic button in CF however, the version isn't supported by the plugin! Doesn't allow for muting etc
    Also, it seems to make Sygic buggy? Runs fine as a standalone app but when it's inside centrafuse it just seems a bit rough?
    Any ideas?
  8. #38
    Aug 2008
    the RC-versions are already patched for cf/carpc-frontends
    i made it this way:
    copied the windowsxp directory from inside the sygic and renamed it for example windowsxpbackup
    then i copied the patch to the windowsxp directory and installed the plugin SygicCF
    after having successfully installed the plugin i deleted windowsxp and renamed the windowsxpbackup to windowsxp
    then you have to switch the Mute hotkey in CF to Alt+6 to work with Sygic...
    perhaps this helps
    rc11 and rc12 work this way but rc12 doesn't mute ... perhaps they've changed the hotkey that is sent out by sygic. i will find out
  9. #39
    Jun 2009
    What patch do you install in to the newly created windowsxp directory?
  10. #40
    Aug 2008
    http://www.mp3car.com/vbulletin/cent...ml#post1255672
    you only copy the patch-files to your windowsxp folder because of the plugin. this will install completely only with this patch
  1. Sygic Drive and Phone opens IE?
    By Dragonlove in forum Road Runner
    Last Post: 06-25-2008, 06:22 AM
  2. Centrafuse 2.0 RC1
    By veetid in forum Centrafuse
    Last Post: 04-21-2008, 10:08 PM
  3. Replies: 0
    Last Post: 03-12-2008, 05:31 PM
  4. hard drive heads on a 2.5" drive
    By zyzzx in forum General Hardware Discussion
    Last Post: 03-02-2006, 12:09 AM
  5. Hard drive dilema.... 2.5" or 3.5"?
    By 3Tripnip in forum General Hardware Discussion
    Last Post: 01-14-2006, 12:30 AM
