Results 1 to 5 of 5
Thread: Visualizations on Sat Radio screen
    Variable Bitrate Jistari's Avatar
    Dec 2007
    New York
    Recently changed MB's and with the new MB I had the vendor install CF V2 (registered XLE).
    Everything works fine, but I seem to remember having the ability to use interactive (react to music) visualizations on the XM screen?
    Now if I tap the visualization area, I can change the visualization, but they dont react to the music at all. When in the Media player screen the visualizations work fine, can change them, ful screen, react to music.
    The Sat radio and MP3's are set up the same as they were with the other MB's (mp3,s on a second drive and the XM coming in on the aux in jack on the pc).
    Anything I can do about this in V2?
    PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D/i7 still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
    VENDOR - Centrafuse veetid's Avatar
    the visuals should work if you have buffer enabled...
    david
    Dec 2007
    New York
    Ah, that may be it, because I definitly have that off. But I aslo had that off when I was using V 1.42 and I got them then?
    Oh well, Ill turn it on, Thank You David
    So what is buffering actually doing? running the xm feed to disk? memory ? then putting it out on aux?
    Should enabeling buffering have an impact on system resources used or cpu load?
    it will have some impact, it does use more resources... it records to the disk and plays back, which allows you to have EQ and Visuals...
    there were some older visuals that moved and "acted" like they were responding to the music earlier, but now they actually do, but only with music files and when using buffer...
    david
    Dec 2007
    New York
    Ah Thank you Dave.
    The quick responsiveness in support of CF is one of the biggest benefits of this front end.
  1. Boot up 3 times @ 800x600, 4th time at 800 x 480???
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-31-2008, 09:31 AM
  2. sat radio antenna
    By RAMRunnr in forum Car Audio
    Last Post: 08-28-2007, 12:24 AM
  3. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
