Results 1 to 3 of 3
Thread: help with shell problem
    Sep 2006
    i just uninstalled centrafuse 1.x because i finally got around to installing v2 there was an unexpected error when uninstalling. i had centrafuse running as a system shell and now centrafuse is gone but windows does not load. only the desktop backround loads and if i try to run explorer.exe in the task manager nothing happens. any help would be appriciated
    Elsewhere
    Can you boot into Safe Mode?
    If so, you may be able to set your shell back to EXPLORER.EXE int he registry.
    If not, I don't know what to tell ya.
    How about the Wiki?
    VENDOR - Centrafuse veetid's Avatar
    ctrl-alt-del, run RegEdit, replace centrafuse.exe with explorer.exe in the registry for the shell application...
    HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
    then close Regedit and either reboot, or run explorer.exe again...
    just to be safe, it is best to disable shell before you uninstall...
    david
  1. USB hub problem always disconnecting / connecting
    By fire in forum General Hardware Discussion
    Last Post: 09-25-2009, 02:30 PM
  2. Replies: 17
    Last Post: 10-29-2006, 10:55 PM
  3. Strange power suplly problem.
    By seninha in forum Power Supplies
    Last Post: 10-22-2006, 05:32 AM
  4. Replies: 6
    Last Post: 07-06-2006, 10:28 PM
  5. Problem shutting down with RR as shell
    By flipster125 in forum Road Runner
    Last Post: 04-17-2006, 02:02 AM
