Results 1 to 10 of 12
Thread: GPS not connecting??
    Nov 2006
    Youngstown
    I downloaded the centrafuse 2.0 trial a couple days ago and started to play around with it. So far I have not been able to get centrafuse to recognize my gps dongle. (bu-353). The gpsinfo program that came with the bu-353 recognizes it and seems to be working fine. I transfered the com port and baud rate settings over to centrafuse but it will not lock on to any satellites or show any signs of working at all. Is there some thing I am missing?
    "Who run Barter Town?"
    VENDOR - Centrafuse veetid's Avatar
    make sure to use a COM port lower than 10, such as COM 1-9, also try changing the baurd rate between 4800 and 9600 just to see if it connects...
    some users if that does not work have good luck with xPort fixing all issues with that receiver...
    david
    Nov 2006
    Youngstown
    Well I tried changing the com port and baud rate settings but I still have the same problem. If I am using the trial version and I don't live in New York or Berlin will the navigation in centrafuse even work?
    you should be able to see the arrow turn green, and see altitude, as well as current number of locks sats if you click it and toggle info screen in navigation...
    david
    Newbie audi's Avatar
    Dec 2005
    GREECE RHODES ISLAND
    centrafuse 1.47
    i have the same problem in ver.147 but only when i restart windows i have to get in menu settings gps settings and just save setting and after that everythink work this is the 1 problem the 2 problem is that when i am driving i notice that map is 40meter behind that my car is and i dont know if this problem of bu353
    both those 1.47 issues should be addressed in 2.0...
    david
    Sep 2006
    The intarwebs
    i have the exact same problem. i need this fixed so my dad will buy a copy of centrafuse!
    Planning {[][][][][][][][][][]} 100%
    Funding {[][][][][][][][][][]} 100%
    Construction {[][][][][][][][][][]} 60%
    if you still have this issue, check the Flux forums release section for the latest 2.1 release, it was put out today...
    it has improved code for GPS connectivity...
    david
    Sep 2006
    The intarwebs
    nope. still borked. no idea why.
    Jan 2006
    Just downloaded and installed CF trial...same issue. Does the receiver have to be connected when the software is installed or can you hook it up afterwards? Sorry for the newbish questions and old thread bump. BTW the receiver works fine for CoPilot set at 9600 on COM3...tried changing to these settings but no luck. Thanks.
  1. VB.Net FrontEnd with SourceCode (formerly VB6)
    By ClockWorK in forum Driveline
    Last Post: 09-11-2010, 05:18 PM
  2. Replies: 353
    Last Post: 08-24-2009, 10:31 AM
  3. SD Navigation just does not work.
    By rumy in forum StreetDeck
    Last Post: 03-10-2007, 08:11 AM
  4. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 01:11 PM
  5. Replies: 5
    Last Post: 10-24-2002, 12:00 PM
Tags for this Thread
