Results 1 to 7 of 7
Thread: silabs radio hiss out of standby
    Dec 2006
    using centrafuse with silabs radio, when the computer comes out of standby I hear a constant hiss. going into radio then exiting resolves the problem.
    Also how do you stop the radio? It seems the only way one finished with the radio is to go into playlist. radio then stops.
    any ideas?
    VENDOR - Centrafuse veetid's Avatar
    if you want to stop listening to radio, you turn down the volume, or change the source like going into Media...
    in buffer mode you can pause, and in non-buffer mode we are looking to make play/pause mute the radio device...
    david
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Quote Originally Posted by Alfredbra View Post
    any ideas?
    I have this problem as well. To clarify David, the problem is if you have been listening to the radio and then switch to playlist before hibernating/standby, when you resume, although the playlist will start playing properly, there is a hiss in the background. The only way to get rid of the hiss is to go from playlist to radio and back to playlist or close CF and reopen it.
    I installed my carpc into my pet Kangaroo, mate.
    Newbie rockking's Avatar
    Jun 2007
    I have exactly the same problem with the hiss after hibernation.
    Any solutions to this problem yet ?
    Nov 2006
    Not that I'm aware of.
    I just opened a bug report on the CF forums
    http://forums.fluxmedia.net/bug-repo...on-resume.html
    we are looking into it, follow the bug on the flux forums...
    david
    Apr 2008
    i had the very same issue when using roadrunner on xp sp2 the radio would not init after resume and you had to change to a different preset to get it working . but with centrafuse the radio works perfectly every time .
    init properly after resume . not sure what dll is been used but this alone is a godsend
  1. Radio solution with RDS & TA (TMC possible)
    By ReflexNPG in forum Hardware Development
    Last Post: 08-04-2009, 04:34 PM
  2. Silabs USB Radio sound issue in RR
    By Nanner in forum Road Runner
    Last Post: 08-29-2007, 07:47 AM
  3. XM Radio Whine / Hiss
    By xbi0s in forum Car Audio
    Last Post: 08-15-2006, 09:32 PM
  4. how can i use my existing old school am radio controls
    By 72chevyPickup in forum Car Audio
    Last Post: 01-11-2006, 11:33 PM
