Results 1 to 5 of 5
Thread: CF INFO in AUTOIT
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Question CF INFO in AUTOIT
    Question (1)
    In RR I am able to pull label data and variables from RR and use it in autoit. How this is done is I use this line of code which allows me to get data from RR:
    PHP Code:
    $AUTOITVARIABLE ObjCreate("RoadRunner.SDK"
    Then I am able to get any info from RR using this code
    PHP Code:
    $AUTOITVARIABLE2 $RR.GetInfo("=$RRVARIABLEORLABELCODE$"
    Is it possible to use this same method in CF.
    Question (2)
    If the above is possible am I able to send data back to CF as a custom variable.
    RR has a command called setvar that lets me set a custom variable like this:
    PHP Code:
    setvar;CUSTOMVARIABLE;HELLO WORLD
    So then I could display CUSTOMVARIABLE as a label code and it would display the text HELLO WORLD.
    The code I would use in AUTOIT would go something like this.
    PHP Code:
    $rr.execute("SETVAR;CUSTOMVARIABLE;HELLO WORLD"
    MAYBE this sounds like a noob question to a lot of you but I am a noob and cant seem to find any info relating to this and I am just trying to figure this CF thing out for the first time.
    Any similar methods or ideas are welcom..
    Thanks in advance
    New Age Garmin - Skin for RR
    Aug 2006
    West Allis, WI
    Also if this is possible where can I get a list of variables and commands for CF?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    What are you planning on doing TS?
    I don't think CF has those things as standard. What may have to be done is a plugin that pulls some onfo out of CF and makes it available to other programs.
    Even so I don't think there will be as much info available as you are used to in RR
    Aug 2006
    West Allis, WI
    OK, thanks.. that confirms what I thought.
    I am just trying to figure out CF and what it is capable of.
    I would like to make a plugin but realized I have a lot to learn as far as programming goes before I can feel comfortable with doing so.
    I havent been able to find any good examples of code used for pluggins in CF. I downloaded the SDK but it is not as self explanitory as I would need.
    The plugginn you mentioned above would be awsome. That is actually what I wanted to do in the first place. I just dont know where to start?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Actually the two examples (hello world, simple list) that come with the SDK are very useful, once you get in there and change things, break them, and then start all over again.
    There are somethings you have to find out for yourself though and I am still finding new things, some of it is to to with CF other times it is with VB.net or .net in general.
  1. mediate ice - new free DirectX based front end
    By athomemedia in forum Software & Software Development
    Last Post: 09-08-2008, 03:25 PM
  2. Streetdeck Rollback
    By brombomb in forum StreetDeck
    Last Post: 01-23-2008, 09:28 AM
  3. Flash OS
    By BiohazrD in forum General Hardware Discussion
    Last Post: 12-04-2004, 09:57 AM
  4. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
  5. CF, want to know some info
    By superzz in forum General Hardware Discussion
    Last Post: 08-21-2003, 07:13 PM
