Results 1 to 9 of 9
Thread: My Centrafuse gets an error message :S
    Jan 2009
    Hi. I tested CF on my computer yesterday and was extremely happy about how it worked, so today I installed it on my carputer, but CF keeps getting error messages when operating the music. Its a windows message sayng that CF has a problem and have to be closed. The message seems to pop up at random as long as I am fixing my music. I've tryed transfering all my songs to a different partition, but the problem is still there. Whats wrong?
    The carputer is a Socket 754 AMD Sempron 2800+ with 1GB DDR-DIMM RAM, 128mb integrated VGA and 20GB IDE HD. I run Winxp on it.
    Dec 2008
    Mine is doing the same thing. I get a message saying something like Centrafuse has reached an end user breakpoint. I am going to try reinstall centrafuse when I get off work today and see if that helps at all b/c mine was playing my music fine until I got the HD Radio working.
    Jan 2009
    Some help with this would be great. Every aspect of the carputer is now finished, the only thing left is to plug it in :P So having this problem stalling me really ****es me off Did it work to reinstall CF flnole78?
    Dec 2008
    Well actually I didn't have to reinstall it. I was having issues with my onboard sound card and my PCI sound card battling each other apparently. I disabled the onboard sound card in BIOS and set my sound blaster card as the default and the problem went away.
    Exactly what does the message that you get say? I was getting another message saying centrafuse cannot play AAC files for a while then I read on forums.fluxmedia.net that their is a .dll file that you have to download and put in your/centrafuse folder. I downloaded that and that message went away. So if you are getting that message when you try to play your mp3's then just check out this faq and follow the directions to download:
    http://forums.fluxmedia.net/faq.php?faq=media#faq_ipod
    Jan 2009
    "Centrafuse has encountered a problem and needs to close. We are sorry for the inconvenience." "If you were in the middle of something, the information you were working on might be lost".
    It doesnt say much I can see that this only happens if I try to enter my music. We are talking about 1600 songs and I know there are some songs that are spyware and some that is corrupt. The same songs worked perfectly on my other computer though, so I cant see why this would be the problem, but I'll try to filter out some of the bad files :P
    Jan 2009
    I give up. I tryed to make a new music folder, copying some songs at the time and tested if the folder worked on CF, I found one song that messed it up (strangely enough it was nothing special about this song, regular mp3). I removed this song along with all the files that were under 1mb of size. I thought this fixed the problem, everything worked fine so I started to go through the songs creating a playlist. After 10 min of work and reaching S the error message appeared :S I could continue go through the files, copying bits and bits, but if I have to use 10 min to make a playlist everytime just to check if everything is ok I cant say that it makes it worth my while :P I really need help
    Dec 2008
    Well mine worked on my carputer for a few days then all of a sudden got that message. I downloaded that .dll file the FAQ talks about and haven't had an error since. If you haven't done that yet, I suggest going ahead and putting that file in the centrafuse folder. That way if it does fix it, perfect, if not then you won't have to worry when you come up on an ACC file type.
    Jan 2009
    I think it worked I also installed K-lite mega codec pack and updated windows media player, but the importaint case is that its working Thank you
    Dec 2007
    I fixed this problem by updating Windows Media player. I was experiencing the problem with wmp9. I updated and tried my hardest to get the error to come up, but it looks like its fixed.
  1. Centrafuse 2.0 Final
    By Jan_RedGTiVR6 in forum Centrafuse
    Last Post: 08-17-2008, 01:35 PM
  2. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 09:31 PM
  3. Centrafuse 2.0 RC3
    By smeesseman in forum Centrafuse
    Last Post: 05-21-2008, 10:29 PM
  4. Centrafuse 2.0 RC2
    By Ogold007 in forum Centrafuse
    Last Post: 05-21-2008, 03:59 PM
  5. Centrafuse 2.0 RC1
    Last Post: 04-21-2008, 11:08 PM
