Results 1 to 2 of 2
Thread: help, centrafuse changed size/location..
    Nov 2007
    Michigan
    I've been trying to work out the bugs on my system, and a new one has risen. I left my flash drive plugged in and when I restarted the pc, it checked for consistency on the flash, when I started centrafuse, it was high and to went off the screen to the right. I can't find the setting to change it back to 800x640. Anybody run into this problem?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You need you enable advanced settings, it then should appear under graphics page 2 I believe.
    Thread also moved to Centrafuse forum.
  1. Replies: 1158
    Last Post: 04-06-2011, 10:38 AM
  2. Has anyone changed from Streetdeck to Centrafuse?
    By polo6979 in forum StreetDeck
    Last Post: 08-31-2008, 10:35 AM
  3. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  4. centrafuse problems when using minlogon
    By sregger in forum Centrafuse
    Last Post: 03-04-2007, 10:50 AM
  5. Centrafuse Launcher (Fixes Map Movement)
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-02-2005, 03:53 PM
