Results 1 to 7 of 7
Thread: Centrafuse: Should I import media or not?
    Nov 2008
    I'm storing all my media on an external / portable hard drive powered through USB.
    When you plug it in, Centrafuse asks if you would like to import the music.
    Will importing the songs copy the songs onto the PC hard drive? Or just remember there locations and create links to the portable?
    It's just I don't want to clog up my small CarPC HDD with music - when I've got a large external hard drive.
    Hope this makes sense,
    Cheers for the help
    Mar 2009
    near Rochester, NY
    Dunno, do you have a flash drive you can try with a small amount of music on?
    Constant Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    Quote Originally Posted by MichaelPlace View Post
    Cheers for the help
    i would like to know also.
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Constant Bitrate lacning74's Avatar
    Apr 2008
    I just recently imported some via a SD card. It copies the music with the respective folders into your music directory so it will clog up of HD. Turn off the auto-import option if you don't want the prompt.
    If you use a portable hard drive, just add it's directory as a location for music in the Audio/Video settings and re-update your library.
    Nov 2008
    Cheers, I've managed to add the folders to the list just wondered if it was easier to import - but it looked like it was copying so I never bothered.
    Dec 2005
    Raleigh, NC
    I've never imported, just had it add to the catalog. How does that work with the big external drive? I wouldn't mind getting one of those portable ones (that run off one single usb cable) and use that for media instead of keeping them all on the hdd (then I could use a small CF card or something for OS).
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
    Apr 2008
    Quote Originally Posted by ik632 View Post
    works fine as long as you have a reliable portable hd and spare usb port (will usually need it's own, not a hub). i've had no issues with my 120gb WD Passport.
  1. OLD Wifi Manager - No longer supported
    By EL CAMINO in forum RR Plugins No Longer Supported
    Last Post: 04-06-2010, 11:20 PM
  2. Centrafuse 2.0 Final
    By Jan_RedGTiVR6 in forum Centrafuse
    Last Post: 08-17-2008, 01:35 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  5. Mobile Media Center Features
    By Bitoholic in forum Mobile Media Center
    Last Post: 11-29-2004, 09:04 PM
