Results 1 to 10 of 14
Thread: no GPS after standby
    Dec 2006
    wondering if anyone has this issue also with the BU-353 GPS USB reciever.... Most of the time comming out of standby centrafuse wont get a gps position. If you exit centrafuse and re open it everything is fine.
    using latest GPS drivers from globalsat website.
    Elsewhere
    Is the GPS conencted through a USB hub?
    How about the Wiki?
    FLAC WuNgUn's Avatar
    Sep 2007
    Also try enabling delay on resume in the CF options...
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I think that's to be expected with some units, but the BU-353?
    Low Bitrate lbergamo's Avatar
    May 2009
    Michigan, USA
    I solved this by doing a little Googling. What happens is when Windows comes out of stand-by or the like it re-detects all devices like it would when Windows starts.
    First, bring up Device Manager and double click on "Universal Serial Bus Controllers" then "USB Root Hub".
    Second, under it's power managment tab clear the check box that says "Allow the computer to turn off this device to save power".
    This should cure your problem.
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    If you use Xport it will also solve the problem, CF does not know to shut off the port before the computer enters hibernation.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    May 2009
    Michigan, USA
    I am confused ? Is it not the duty of the OS to handle power managment issues ?
    Sep 2007
    Quote Originally Posted by lbergamo View Post
    What exactly does this do? Prevents Windows from redetecting the device on resume?
    Jun 2004
    Westminster, MD
    Usually, however as said above some units like the BU353 have an issue where if you stay connected to the COM port, it won't resume properly (which is bad practice anyway). Hence why XPORT fixes this, it is hibernation aware.
    Mar 2004
    Florence Yall, BFKY
    Yep, the biggest problem is with leaving handles open with serial devices and quite a few other things like audio mixers. The app releases it's resources, then the driver can release its own.
    It's not the OS, but the 3rd party drivers that were probably designed on the NT4.0 skeletons and were never rewritten/upgraded with 5.0 power functions.
  1. 330i ZHP CarPC install - HEADUNIT RELOCATED - Lots of Pics
    By Si_g in forum Show off your project
    Last Post: 07-19-2008, 02:20 AM
  2. GPS too hot in direct sunlight
    By utd09bry in forum GPS
    Last Post: 06-08-2008, 09:55 PM
  3. Replies: 91
    Last Post: 11-07-2006, 05:47 PM
  4. GlobalSat BT-338 Review
    By tom2112 in forum The Review Palace
    Last Post: 06-27-2005, 12:02 PM
