Results 1 to 6 of 6
Thread: Maps problem?
    Constant Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    Maps problem?
    I just started to work with CF and I installed the navigation part of it and why is it that all I'm getting is Canada ? Where are the states? I did purchase CF north America....
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Mar 2009
    near Rochester, NY
    are you looking in the folder? Or if in Destinator have you tried changing the map?
    Aug 2007
    Queens, NYC
    i think i got it now....I have to check it when i get home from work..I will report back later on...
    CarPc
    Project "Driver"
    Planning [99.9%]
    Apr 2005
    I also have a problem with my maps in CF
    I've copied the "North American" folder into my "C:\Program Files\Flux Media\Centrafuse" directory
    and I don't see anything in my Nav
    should I copy out all the subfolders eg: USA1, USA2, USA3 etc... into the "C:\Program Files\Flux Media\Centrafuse" directory?
    thanx
    May 2009
    Quote Originally Posted by blackcar View Post
    thanx
    I think you have to copy all the subfolders, so you only have to open one folder before you see all the individual files.
    Also changing the map is tricky, you have to hit the back arrow when you click setup for navigation, then click change map.
    Apr 2005
    Quote Originally Posted by thestellarinc View Post
    Thanks, I'll give it a try
    If I had to do it again, I would have skipped the Centrafuse navigator
    it looks pretty crappy compared to iGuidance
  1. Replies: 12
    Last Post: 08-26-2008, 07:37 AM
  2. Problem with loading maps
    By doddyz in forum GPS
    Last Post: 11-29-2006, 03:40 PM
  3. Replies: 17
    Last Post: 10-29-2006, 11:55 PM
  4. Strange power suplly problem.
    By seninha in forum Power Supplies
    Last Post: 10-22-2006, 06:32 AM
  5. Problem with loading maps
    By doddyz in forum Map Monkey
    Last Post: 09-09-2005, 10:14 AM
