Results 1 to 4 of 4
Thread: CF3 Trial crashes on build/rebuild...Fixed
    Newbie SCIONology's Avatar
    Dec 2009
    Hickory NC
    Hi, whenever i try to build or rebuild my library CF crashes, i get a microsoft error reporting window.
    i even created a new folder and put just a few mp3 files, nothing else: still crashes.
    i'm running xp pro.
    i have also tried in safe mode to see if something was running causing it to crash, still crashes in safe mode.
    i re-downloaded, re-installed all that, still crashes.
    thanks for the help
    Scion xB G2
    Planning: [----------]
    Parts: [----------]
    Install: [----------]
    My Scion PC Project (put on hold until I find a nicer host):
    Worklog
    Aug 2005
    ditto mate, im seeing the same thing , but mine just hangs
    VegasGuy's Avatar
    May 2009
    Las Vegas
    You might want to check and make sure that SQLCE 3.1 was successfully installed by the CF3 installer on your system. This is a requirement and a failed install would definitely effect the media load process.
    It should be visible in your installed programs as Microsoft SQL Server 2005 Compact Edition [ENU] with a file date of 9/1/2009 (yours might be later)
    VegasGuy
    Dec 2009
    Hickory NC
    sweet, i went to add/remove programs and uninstalled the 'Microsoft SQL Server 2005 Compact Edition [ENU]'
    i then launched the centrafuse installer and it prompted me to reinstall the server, then once that was done i just went ahead stepped the rest of the way through the installer and did a repair.
    i restarted my pc and started centrafuse, and it worked, i went to system, library, rebuild and it worked.
    i'll see if i can get a moderator to move this, not a bug.
    Scion xB G2
    Parts: [----------]
    Worklog
  1. Release new phoco integration preview
    By Robby BMW in forum Road Runner
    Last Post: 09-12-2009, 06:29 AM
  2. Latest Build - 2014-06-11
    By ClockWorK in forum Driveline
    Last Post: 06-11-2009, 04:29 PM
  3. 05/27/08 Road Runner Official Beta, Weather Fixed!
    By JohnWPB in forum Road Runner
    Last Post: 09-02-2008, 07:06 AM
  4. XM / Sirius Worklog
    By Nola111 in forum Centrafuse
    Last Post: 08-20-2008, 11:05 AM
  5. Download StreetDeck Updates
    By god_of_cpu in forum StreetDeck
    Last Post: 07-31-2008, 08:35 AM
