Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: MY Centrafuse stuff
  1. #11
    Variable Bitrate csfile's Avatar
    Feb 2009
    Quote Originally Posted by creaseguard View Post
    Csfile, are you able to tune to HD stations in CF3? I cannot get them to tune. I've turned off auto right click on the touch sceen and press and hold the am/fm button and can't get the stations.
    I've noticed there are a couple other settings on the touch panel software, wondering if I have one or more of these set wrong so that CF is not recognizing my continuous touch...although the color of the button suggests it is.
    Yeah, for me I still have auto right click enabled. When I try to hold down the button, I just have to keep moving my finger around on the button so the right click doesn't go.
  2. #12
    Feb 2009
    I just saw this thread:
    Quote Originally Posted by S4per
    Update: my touch screen has, what seems, 2 relevant settings for this: 'enable constant touch' and 'enable right-click'. I've turned both of them off, and so far, the responsiveness and accuracy of the scrolling list feature is at 100%. So - at least for me - seems like issue solved.
    Maybe this may help you as well.
  3. #13
    Aug 2007
    I found that if the main frequency is not an HD station, then you cannot tune to any sub stations.
    For example, 103.3 in Dallas is an HD station. Subsequently, I can tune to the sub stations by holding down the fm key and then I can cycle through the stations.
    However, 99.5 is not an HD station but there is an HD substation at 99.5 HD-2. Since the primary station is not HD, CF does not recognize the press and hold to cycle to other stations and does not tune in the HD-2 station.
  1. Centrafuse 2.0 Final
    By Jan_RedGTiVR6 in forum Centrafuse
    Last Post: 08-17-2008, 12:35 PM
  2. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 07:12 PM
  3. No Sound in Centrafuse after Hibernate
    By barmy in forum CF Bug Reports
    Last Post: 07-26-2007, 11:45 AM
  4. Replies: 0
    Last Post: 11-26-2006, 07:25 AM
  5. Centrafuse Launcher (Fixes Map Movement)
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-02-2005, 02:53 PM
