Results 1 to 10 of 11
Thread: Centrafuse + Mac Mini + Win7 =?
    Jan 2010
    Long time reader first time poster. I wasn't sure if this should be in MacCar or Centrafuse sub-forums. Owell.
    First of all, YES i did search, but I wasn't happy with and/or didn't understand the information I found.
    Ok so iv finished my mac mini install. Mac is in, Fab is done, Electrical is done. All i need is a front end. I always figured that by the time I had finished my install someone would have made a good OS X FE. Alas my hopes were futile. I am bitterly disappointed with all the current os x front ends.
    Enter Centrafuse. Its awesome! Except I have just one problem.... I have a mac (early 09 mini).
    Oh wait, before i get to far into this, I have grown up with macs. I am a Windows N00B, So please, laymans terms only . Mac-wise, I consider myself pretty switched on. I can use msn and basic stuff on Windoze, but I have no idea where the control panel is for example.
    I want to Know what my options are. I can easily obtain a copy of Windows 7 (shiver). Im thinking Bootcamp + Win7 + Centrafuse. But i have a few questions.
    1. How well does Win7 and Centrafuse integrate with the mac mini and Carnetix P1900? As in will it start up/shut down and Sleep as it would with my mini? Or is it a PITA?
    2. What are the "Boot" and "wake from sleep" times like? And what can i do about them?
    3. Can I boot straight into CF or do i have to f*** around with windows?
    4. Can I use my Griffen Radio shark 2 with CF? Like wise with my BU-353 GPS Receiver.
    5. Can I Use my Behringer UCA 222 to output sound to my amps?
    6. Will CF do Phonecalls with my iPhone 3GS?
    7. What maps will i need for Australian GPS Navigation?
    8. What other problems am I likely to face with a set-up like this?
    My Hardware is as follows:
    • Early 09 Mac Mini 2.0ghz C2D (4Gb Ram, 500Gb HD etc)
    • Behringer UCA 222 sound card
    • Griffen Radio shark 2
    • BU-353 GPS Receiver
    • Logitec 4way USB Hub
    • External Optical Drive
    • Carnetix P1900
    • Carnetix MacPac
    • Lilliput 09 629 LED TS
    Whats are your general thought on this setup? Will it ever work the way i want. Also add any information that may be useful.
    Thanks a billion
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Here's how it works - you can set it up to boot Windows and you can set up Windows to boot CF. Done.
    The only question will be whether or not the sound card or unusual peripherals will work under Bootcamp. In general, the answer is -if they work in Windows they usually work in Bootcamp running Windows.
    The system will startup and shutdown with the P1900 as you desire.
    Essentially, what you will have is a Windows system. All solutions and configurations after setting up Bootcamp for Windows can be found in Windows forums.
    Want to:
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    If your running a carPC FE full screen why do you care what OS is underneath it?
    Jan 2010
    Thanks BugByte. CF supports my GPS receiver and the sound card has ASIO drivers. so they should be ok. However im still concerned about the Radio Shark 2... I cant seem to get a straight answer out of anyone.
    Well I care because the OS determines what Front End I can run.... And all the OS X Front Ends pretty much suck....
    Whats a Better option for Car PCs of this Nature, Win7 or XP?
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I am currently running a setup in the manner that you're considering. It's has it's pluses and minuses, as you'll see.
    Quote Originally Posted by Lachie View Post
      The Carnetix will work fine as long as it's all wired and jumpered correctly. Then you just have to set the power button options in Windows so when you shut your vehicle off it either suspends, hibernates or shuts down.
      Without any optimizing, you're probably looking at 60 second cold boots, 30 or so second hibernation resumes and maybe 5 to 10 second wakeups from suspend. There are some optimization methods to shorten those times but the Mini is very slow to boot.
      There are multiple options to go right to CF rather than to the Windows desktop.
      I can't speak to if the radio shark works, but if it has a Windows driver it should work. The BU-353 works fine.
      Again as long as it has Windows drivers ti will work.
      No clue, I would check the fluxmedia forums.
      There's a version of CF you can buy that has the Aussie maps.
      Obviously not being comfortable with Windows is an issue.
    I'm still running XP on my setup. No real motivation to reload as Win7. Either should work fine.
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    i run win7 on my mac mini and everything runs very smooth, CF runs great i have had no problems.. i have the p2140 i think from carnetix same thing with 5v on it and it works great and was easy to setup... the only issue i have now as i seemed to have fried or done something to my PSU as it only outputs 7v but mp3car offered to fix it for me so i just have to ship it in
    Oct 2006
    Don't get my wrong, because i'm a die hard mac fan, but why buy a mac to put windows FE on? for the price there's many other nice choices. the only nice thing about the mac mini is the small size.
    Nov 2006
    Mentor, OHIO
    Quote Originally Posted by Punky View Post
    i bought this because the size was 100% perfect for the location of where i was placing the mini... i have never regreted buying the mini... i had 3 other systems b4 this and this has not only been 1 of the best performers for the $$ but also best in size
    Oct 2006
    Mac bios isn't designed for windows bootup, so its kinda slow in my opinion (running bootcamp).
    anyway, i don't think you'll have any issue using it as a PC, but check out ICE3 in the mac section, it'll make you think twice about windows FE. Its still underdevelopment, but its freaking awesome.
    Jun 2007
    In my case, the system was ideally sized for my needs. Nettops or other compact systems that you can buy now weren't available. If I was to redo my system today, I wouldn't go with a Mac Mini.
    Mac bios isn't designed for windows bootup, so its kinda slow in my opinion (running bootcamp). anyway, i don't think you'll have any issue using it as a PC, but check out ICE3 in the mac section, it'll make you think twice about windows FE. Its still underdevelopment, but its freaking awesome.
    I agree it is a bit slow, but an OSX bootup isn't any faster. There's no sirius satellite radio support in any of the OSX based FEs, so ICE3 isn't a functional option for me.
  1. Mini Mac 4 Porsche 944
    By 4thChild in forum MacCar
    Last Post: 03-13-2009, 11:16 PM
  2. Installing Mac Mini in My 05 Alti SER
    By Vitulla in forum Newbie
    Last Post: 05-24-2007, 12:55 AM
  3. Overheating your Mac Mini - No problem!
    By Bugbyte in forum MacCar
    Last Post: 12-08-2006, 10:46 PM
  4. 2005 Scion xA- Mac Mini
    By Doomspat in forum Worklogs
    Last Post: 11-27-2006, 11:07 AM
  5. FS: Mac Mini CarPC Package/Parts LOADED!
    By markcc01 in forum Classified Archive
    Last Post: 01-03-2006, 11:47 PM
