Results 1 to 10 of 12
Thread: I need a DLL file so bluetooth will work
    Feb 2010
    I have got Centrafuse installed and Bluesoleil installed, but Centrafuse will not detect my dongle.
    It seems I need the latest version of bsdneti.dll , but the download link on this page http://forums.fluxmedia.net/release-...h-release.html will not work.
    Does anyone know where I can get that DLL from ?
    Jan 2008
    Dartmouth, MA
    Have you stripped down windows at all? Does Bluesoleil support your dongle? Have you uninstalled and reinstalled bluesoleil?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Feb 2010
    I have been working on this all damn day, but have finally found the dll file I needed, just copied into the centrafuse folder and tried my bluetooth again and it now works and I have my phone paired with centrafuse. . . . I'm over the moon. .. almost ready for the installation into the car now.
    Aug 2007
    I hate to burst your bubble, but the first call you make you will find out the other end hears a nasty echo. Well known problem I discovered last night after getting my phone paired and working.
    Jay
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    depends on your sound card. If you have a realtek based board, there is a software side echo cancellation option. Works perfectly.
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
    Sep 2009
    Where did you find the DLL? I cannot get Bluesoleil to see my internal Bluettoh at all, but their hardware checker says everything is fine. I even did a clean install of xp and did not load the Dell driver for my bluetooth. Did a clean install of Centrafuse and Bluesoleil and notihing, Bluetooth not found.
    Nov 2005
    Toronto, ON
    you may have to edit the driver files to recognize your specific BT dongle. There is a post on the Flux forums on how to do it. It's quite easy and has worked every time for me.
    I'll try to find it for you.
    Nov 2005
    Toronto, ON
    Right, can't find the thread, don't know where it went...
    But here is how you do it (combining my own instructions and someone else's):
    Open device manager
    Right click on your bluetooth, select the details tab, and under property, select Hardware IDs, copy whatever you have in there (USB\VID_0000&PID_0000 or whatever, you might have &rev_0000 as well, copy both lines into notepad). DO NOT CLOSE DEVICE MANAGER, you will be coming back to it.
    Add the following lines to:
    IVT Install Dir\Bluesoleil\driver\usb\btcusb.inf
    After line:
    [ControlFlags]
    Add line:
    ExcludeFromSelect = [insert your hardware id]
    After line:
    [IVT]
    Add line:
    %[insert dongle name]%=BTusb_DDI, [insert your hardware id]
    Under line:
    [Strings]
    After line:
    SourceDisk="BlueSoleil Installation Disk"
    Add line:
    [insert dongle name] ="[insert Dongle name]"
    IVT Install Dir\Bluesoleil\bttl.ini
    Under line:
    [DEFAULT]
    Change line:
    NUM=*** (where *** equals a 3 digit number)
    To:
    NUM=***+1 (eg. 309 + 1 would become 310)
    Scroll to the end of the file and find the last entry for heading [HW***] where *** equaled the same original number above eg. 309
    After the last entry copy these lines where *** equals the last new number in the sequece eg. 310
    [HW***]
    ID=[insert Hardware ID]
    Type=USB Bluetooth Dongle
    DLL=Driver\USB\btcusb.dll
    DLLD=Driver\USB\btcusbd.dll
    Inffile=Driver\USB\btcusb.inf
    Manufacture=[Insert Dongle Manufacturer]
    Update your bluetooth driver:
    Navigate to the Bluetooth device in Device Manager and select "Update Driver ..." and select to install from a specific location.
    Restart your computer... start bluetooth, pair away!
    Sep 2009
    Thanks I will try it when I get home. Thank you again.
    Nov 2005
    Toronto, ON
    I do what I can...
  1. How to use a configuration file created by the Configurator with MDX
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 09-08-2008, 04:36 PM
  2. Willit work with Parrot bluetooth adapter?
    By carputerwiz in forum StreetDeck Bluetooth
    Last Post: 03-03-2008, 08:19 AM
  3. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 07:32 PM
