Results 1 to 2 of 2
Thread: CF internet port setting?
    Mar 2010
    I'm using CF 3 and just getting started, not even in car yet. I have a Wifi dongle and am trying to set the port for CF to use it. Shows up in Wifi settings and is connected and works great in window environment but in CF, nada through the Web button or email.
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Go into advanced settings and make sure you have your wifi device selected in settings. On your main menu screen, you should see a green bar at the bottom of the screen. This indicates that CF has a network connection. If the bar is gray, CF does not have a connection. CF uses the standard Microsoft Wifi settings, so if you can get it to work in windows, you should be able to get it configured in CF.
    VegasGuy
  1. Instructions on getting FREE wireless internet from T-Mobile using GPRS
    By bankingdom in forum Wireless Communications
    Last Post: 08-16-2011, 03:37 PM
  2. Serial USB Port
    By ssteger in forum VaultWiki
    Last Post: 02-09-2010, 04:05 PM
  3. Palm Pre UI -port to CF?
    By hairyMerkin in forum CF Skins
    Last Post: 07-02-2009, 01:11 AM
  4. CF 1.2 does not open com port for GPS??
    By t_bear in forum CF Bug Reports
    Last Post: 06-20-2007, 05:20 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
